Question about Ryobi Garden
My ryobi leaf gas blower has no spark. will not start.
    Top Expert:
  • Ryobi Master
  • 12,962 Answers
Check plug? Igniter? On/off switch stuck in closed position?
Posted on Apr 24, 2017
I have a factory refurbished Ryobi ZR08510 blower/vac from the factory. I cannot get it started. What should I try first?
Hi Paul:
I'd start by pulling the spark plug, attaching it to the lead, then spin it over and check for spark.
This will probably be a 2 cycle motor (Check to confirm) so make sure your fuel is mixed correctly.
Dec 30, 2015 | Ryobi Blower Vac 205mph Leaf Blower Or...
How to start ryobi leaf blower model 09050 i tried everything i primed it with gas tried shooting starter fluid in it
Do you have a spark on the plug? Did you use gas-ethanol mix?
Use premium only.
Sep 12, 2015 | Ryobi Garden
Ryobi bp42 leaf blower won't start got gas got compression an got spark a light spark? Help
if by chance it was ever run without the proper amount of oil in the gas then the cylinder walls are scored too bad and it will never run . has to have the proper compression
Aug 07, 2015 | Ryobi Garden
I have a ryobi leaf blower model #ry09056 that gets spark at plug but will not start
Make sure vaporised petrol/gas goes into the spark area.
Sep 08, 2014 | Garden
Ryobi BP42 leaf blower will start but will not rev - how can I fix this?
Its actually the opposite of flooding. Its lean. Adjust carb or rebuild carb.
Jul 08, 2014 | Ryobi Garden
My Ryobi 4 cyl 30cc leaf blower just quit starting. Has always started perfectly, but now it just wont start.
replace spark plug.if spark plug okay problem could be carburetor or air leak at fuel lines or check primer bulb for crack which cause air leak.any breaks in fuel line or primer bulb cause air leaks fuel system cause carb not get fuel run engine.
Sep 20, 2013 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 700r trimmer does not start. Changed spark
hve you checked the HT lead and the on/off switch i had the same model as this and i changed everthing but in the end t chucked the thing away and got a sthil modle
Jun 21, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I just picked up a used ryobi rgbv3100 mulcher vacum blower ,it had no gas in it i put the oil gas mix in it ,followed the instructions on the blower ,but cant get it to start ,any ideas on what i can do?
test for spark.
while spark plug is out - put finger over hole see how much compression there is.
If good spark - look for holes in fuel line.
Jul 06, 2009 | Ryobi Garden
I have a ryobi weedeater model 764r. how do i reset the mixture won't start.
I replaced the gas line hose and the spark plug on a 2075r ryobi proffesional weed eater. Now it will not start. Thank you
Jun 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
Top Ryobi Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
