Question about Exercise & Fitness
My treadmill leans to the left side, it's like its missing a support or something, but I don't see anything missing
2 Suggested Answers
  • 753 Answers
SOURCE: lean left bank mulitple miss fires
If you are lean on the left side that rules out a spark issue so you either have a injector cutting out or a vacuum leak on that side.
Posted on Nov 29, 2009
Four keys in Belkin wireless keyboard are not working
If only specific keys are not working, something is obstructing those keys\' pickups which are located immediately beneath the keys. This is almost always caused by food debris or liquid spillage as dust doesn\'t provide particles big enough to cause issues.
If those four keys feel "funny" when being pressed, it\'s almost certainly a physical obstruction. If they feel "sticky" it\'s always a liquid spill. If you don\'t recall spilling anything over the keyboard, use a can of compressed air (found at office supply stores).
Turn the keyboard long side up, with the keys leaning slightly downward. Place the air nozzle close to the intersections of the keyboard, starting at one side and work your way to the other side, using short bursts of air. Repeat for every row of keys. Pay special attention to the four that do not currently work.
You\'ll probably see lots of junk fall out of the keyboard. That\'s good, if so--I would then retest the keyboard (no need to reboot the computer). That should fix it--if not, you may have to resort to pulling off the keys that don\'t work. The next possibility would be broken key hinges, but that\'s beyond the scope of this reply.
For liquids, cleaning is hit or miss. If left long enough, liquids will eat away at the circuits, or provide a short circuit and kill the component. Since only four keys are affected, I\'m really leaning towards food debris, but if you did spill a liquid, you can disassemble the keyboard and clean up any residue under and around the keys. Probably best to use rubbing alcohol and a q-tip for that--but if you\'re not comfortable taking stuff like this apart, it might be time for a new keyboard, or find a handy friend. Good luck!
Apr 07, 2014 | Belkin Wireless Keyboard/Optical Mouse...
Im missing something on the left side of my computer what is it
LOL, it was probably just a PCMCIA slot that had a piece in there to avoid showing an open space. If you never used it, don't sweat it.
Mar 31, 2012 | Acer Extensa 5420-5687 Notebook
No power
Dear Sir:
The Not power can have many reason, plase do the following:
1)Reset the c. breaker from your house(the breaker that control your outlet where do you have connect the treadmill)
2) Please do the same with the breaker from the treadmill
3)Inspect if the treadmill inside after the transformer has FUSE.?
4)Inspect your power cord.
5) Do not use extension cord power if you are using.
6)Smell if you feel something burn?
7)Retight the wires from power cord, and inside from Treadmill.
8)If there are some wires loose or making colder joint.
9)See if there are corroded cables?
Attached is my design for block diagram, for easy troubleshooting.
2_14_2012_7_47_34_pm.gifSincerely. God bless you.
ernesto a cuadra
managua, nicaragua. c.a
Jan 07, 2012 | Exercise & Fitness
4.0L ford ranger runs rough misses under load, idles fine and under full throtle it runs with good power but when you try and go at a constant speed power dies off.. also on left side of engine all 3 plugs...
On the lean area look for a vacuum leak anything there,like PCV hoses and pull the plug on the EGR is there a difference?Is the valve hot at idle? Now check the rich side pull the hose off the fuel pressure regulator is gas leaking out? MAF cant do this, IAC cant do this ,TPS, If everything checks out no vauum no EGR leak No fuel regulator leak you may have to find out if the 02 sensor is reading the correct bank .Bank one could be on bank two, and bank two can be one bank one,It could be mismatched
Apr 30, 2011 | 1994 Ford Ranger Supercab
I am having trouble removing hood/motor cover on Epic 550 treadmill. I have removed 4 - 3/4" screws from front panel and 2 - 1/2" screws from underneath. Still feels locked on. Are there other...
If you lift your treadmill deck up, you will find 2 screws underneath, on the side, towards the front. remove them and that should do the trick.
Nov 23, 2010 | Epic View 550 Treadmill
Ironman Triad motor cover will not come off
To remove the motor cover (#19 from parts list), you have to remove the follow items first:
- Left and right fenders (#20 and #21 from parts list)
- Left and right sideboard covers (#49 and #50 from parts list)
There are 4 screws holding the cover - 2 at the front and 1 on each side. Be careful when you lift the cover, the circuit breaker cable is attached to the cover.
Finally, you may want to reconsider doing that. There is nothing under the cover that requires maintenance. The big *** motor is driving the front tread roller through a belt. The roller has sealed bearings that do not require oil.
Feb 19, 2010 | Ironman Exercise & Fitness
Lean left bank mulitple miss fires
Nov 29, 2009 | 1997 GMC Sierra
My weslo cadence 200 treadmill belt keeps slipping to the left. i keep tightening and loosing it to keep it even but i keeps sliding to the left
please look under the bottom of the treadmill and be sure that your alignment brackets are not benmt/missing. (put the machine in the storage position and look about 2/3 way down the side of the belt) you should see a metal bracket on each side pressing in on the belt. They should be pressing in about 1 1/2 -2 inches to help track the belt.
Nov 24, 2009 | Proform XP Weight Loss 620 Treadmill
Exercise & Fitness Logo
35 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
