Where is the control box for my levelors - Televison & Video
Where are the levelors on a kenmore 21mtfa?
There should be 2 plastic feet at the front and 2 rollers at back. Front feet unscrew to add height.
Jun 08, 2014 | Kenmore Refrigerators
Turn off autofill
if levelor check sensor maybe stuck too high in skimmer or wire cut or stuck water solenoid
Mar 22, 2013 | Jandy AquaLink RS OneTouch RS6 Pool or Spa...
Levelor fails to maintain proper water level
clean the sensor if dirty or slimy it will send false information
May 19, 2010 | Jandy Levolor Water Leveling System - Fill...
I have a 2004 buick rainier with a sagging rear suspension self levelors not working?
The suspension levelors are vaucumn controlled, look for a leak in the vacumn lines and the levelors, sometimes to ease up your search you may use a spray solution of soapy water while the system is engaged to try to pin point the source of the leak.
Kinked, twisted, pinched or broken vacumn hoses are a straight forward sure sign of the problem repair/replace the defect and recheck your work to be sure it is repaired properly after the fix.
May 15, 2010 | 2004 Buick Rainier
there is a control box for the cruise control behind the glove box . You can remove the cover by pushing in from both sides of the glove box door . the control box will be just inside the glove box to the top. it simply unplugs. any junk yard with an aerostar or ranger or explorer will have one of these control boxes fairly cheap. these control boxes are commonly known to just quit workingand are a very easy fix.
Feb 09, 2009 | 1994 Ford Ranger Supercab
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
