Question about Coffee Makers & Espresso Machines
Is there a switch to make the coffee hotter - Coffee Makers & Espresso Machines
    Top Expert:
  • Coffee Maker... Master
  • 12,962 Answers
Check your ****** manual. How can anyone help you with the info you have provided?!?!?!?!?!!?!!!?
Posted on Apr 24, 2017
Why is the coffee not hot enough
Coffee should not be hotter then 98 degrees out of the machine. I have the same problem. before I brew I fill my cup with hot water and that helped me for a hotter cup of coffee. some machines allow you to adjust temperature, eg, Krups
Dec 13, 2014 | Coffee Makers & Espresso Machines
Coffee not hot
It is factory set and you have no manual control to override the settings.
Sep 18, 2012 | Keurig Special Edition B60 Coffee Maker
Hello We have a prima donna machine and
Check your programmed temperature setting; perhaps your machine has been set at low or medium.
Following are the instruction for Setting the Temperature from the manual for the ESAM6700.
1. Press the P button to enter the menu;
2. Press the < or > until "Set Temperature" is displayed;
3. Press the OK icon;
4. Turn < or > until the required temperature (high, medium, low) is displayed;
5. Press the OK icon to confirm (or the ESC icon to cancel the operation);
6. Press the button to exit the menu.
For a hotter coffee, before delivery rinse the appliance through by pressing the Rinse icon and confirming with the OK icon. Hot water
flows out of the coffee spouts and heats the internal circuit of the machine so that the coffee delivered will be hotter.
For an even hotter coffee, heat the cups by rinsing them with the hot water.
Mar 22, 2011 | DeLonghi Prima Donna Avante ESAM6700...
Coffee not hot right after finishing percolating. But gets hotter with time, about 5 minutes.
Hi. you need a thermostst. You perking is turning off to soon, 1 it perks, so the main heating is working, It perked, 2 the keep warm element works because it is keeping the water hot and is making the water hotter. You can get the thermostat from repairshop.com.
It is a very, very easy fit and cheap part. Good luck Ron
Mar 08, 2010 | Faberware Coffee Makers & Espresso...
My Keurig coffeemaker shuts itself off, sometimes before I even brew a cup of coffee.
This is a heating problem.
What usually happens when heating elements start to go, is that they get thinner. This means that the same energy goes through a thinner wire - so it actually gets hotter than it should (like a fuse).
There will be an over-temperature switch that will cut out (to prevent a fire or damage) - so this is tripping off.
Replace the element with a factory original - and try again.
Check for any blackened connections at the element.
Mar 04, 2010 | Keurig B60 Coffee Maker
How can i make the water hotter in my azkoyen Az04/A coffee machine as i cant find an instruction manual anywhere pllllllleeeeeeeeaseeee
increase the pressure in the boiler with the pressure switch but watch you dont make the pressure go to high or it will blow off
Mar 02, 2010 | Coffee Makers & Espresso Machines
Our coffee tastes very weak. Would de scaling help.
This would not hurt, but I think you just need to add a tablespoon or two more coffee grounds or until it is the strength you want.
Only the heat of the water will give you poor quality, the hotter the water
the more coffee comes out from the grounds.
Feb 04, 2010 | Keurig Elite B40 Coffee Maker
Coffee not hot enough Is there a way to modify the factory settings to make coffee/milk warmer for the Nespresso Latissima machine?
Before placing first coffee capsule in the machine, run the large espresso cup button into a cup (clear water will come out). This primes the machine and makes for hotter coffee.
Oct 03, 2009 | Nespresso Lattissima 660.R
The coffee could be hotter
Clean it. Use the manufacturer procedure. If that doesn't work, you can obtain a new thermostatic button. Outlet temp for most coffee makers is 180 F.
Mar 15, 2008 | Mr. Coffee MRCTB Coffee Maker
Hotter coffee
can also - press menu untill temp comes up - set to high.
(only low med and high)
Mar 01, 2008 | DeLonghi EAM3200 Espresso & Coffee Maker
Coffee Makers & Espresso Machines Logo
32 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
