Question about LG Cell Phones
Is there any way to reset timer volume on LG microwave as I am hard of hearing and don't always hear it when its finished.
SOURCE: how to increase volume on A737 for hard of hearing person
Ypu can try going into settings. then sound and then go to voulme And try doing that
Posted on Jun 28, 2008
SOURCE: NOKIA 2760h PHONE VOLUME TROUBLE HARD TO HEAR
according to the manual, you can only adjust the volume whilst you are receiving a call . on the central scroll button press the right hand side ( as you look at it) until it reaches the desired level. hope this helps , j.
Posted on Apr 04, 2009
SOURCE: how to increase ringing volume and hearing volume
When you are receiving a call use the up/down or left/right rocker (the squarish thingy around the circular button in the middle) to increase/decrease the volume. This also works for the speaker volume if you have the speaker on.
HTH
JB
Posted on Jul 05, 2009
  • 18 Answers
SOURCE: my LG cell phone volume only goes to 7. I can not
the problem is the speaker. you must clean or replace the speaker.
Posted on Aug 11, 2009
Testimonial: "yes this was helpful. but can someone tell me how to go about cleaning the speaker?"
apart4u
  • 213 Answers
SOURCE: timer alarm volume is down
iam sorry to tel you there is no way of turning it up you would have to get a new timer
Paul http://www.apart4u.co.uk
Posted on Mar 04, 2010
How do i disable the beeper
Hello Friend, thank you for allowing me to assist you!
I see that your question is listed under Frigidaire microwave FFCE2238LW. Typically you will hear a series of beep once your food is done heating or defrosting has finished. For this purpose, the beeping signal cannot be deactivated and I show that the volume is not adjustable for your model. Most microwaves are preset to do this. Best regards! - Z
Aug 26, 2014 | Frigidaire FFCE2238LW Microwave Ovens
Echos for person I'm talking to how do I fix this
Ann
Does this always happen? Have you tried a reset?
HX550 Reset to factory default
Mark
Motorola Support
Mar 27, 2014 | Motorola Mobility HX550 Bluetooth Headset
LGC320 always on Headset profile
The problem with your phone is the ear piece since the volume of your phone is at maximum, yet you cannot hear anything, this indicate earpiece problem, you will need to replace the earpiece of your phone in other to hear your caller or when you make call.
Jul 25, 2012 | LG C320 Cell Phone
Cell phone speaker for ear doesn't work but speaker phone does.
Make sure all the volume is up. If you sill don't hear anything, speaker or wires might be faulty. Needs servicing.
Jan 29, 2012 | LG Cell Phones
I have a Salton micorwave oven (MW-2027P). The timer works but the cook setting will not start. There is also no light on the inside when I open the door.
I had this exact same problem with my salton microwave! Even tried taking it back to the store, but with no reciept there was little they could do. Anyways try jiggling the clasps on the side of the the door, the ones that connect it to the microwave. Mind you don't jiggle too hard. Now firmly close the door, you should hear a distinct click. Now try it! The light only works when the microwave is on. The microwave won't work unless the door is closed properly and my problem was the claps were stuck! I hope this helps.
May 15, 2011 | Salton RRMW1 / RRMW1A 900 Watts Microwave...
My lg kf750 secert has no sound. I have checked volume. When the phone rings there no sound and i can't hear person on line but they can hear me.
Firstly, try to go to 'Menu > Settings > Reset settings'. This will clear only your personal preferences, thus not touching your applications or personal data. However, ff you keep having problems with your sounds, perhaps a hard reset could sort your problems out. Be warned that a hard reset will set everything on your phone to their factory defaults, for what you'll loose all programs you have installed, as well as your personal data. To perform a hard reset, turn your phone off completely, by pressing and hold the power button and answering to the prompt. Then, press and hold the Volume Down, the Call, and the Power buttons, until the LED (at the side of the camera) flashes. Release the buttons. That LED should flash in green/red/blue. When your device powers up, it should be completely clear now.
Hope it works for you, since this is pure theory. I have never done it myself.
Cheers! Carlos
Apr 17, 2010 | LG Secret ? KF750 Cellular Phone
People cannot hear my voice very well (volume is too low) when I am speaking.
On the side of the phone there are two arrows, one stands for plus volume, the other stands for Minus volume... Try It!!!
May 21, 2009 | LG Vu CU920 Cellular Phone
Clock timer volume too low
The beeper sound level can be adjusted.
Press the "BEEPER VOLUME" pad on the keypad, then select 0–3 for mute to loud.
Your owner's manual is here.
Jan 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
LG microwave no longer heats!
It sounds as though you may have run the microwave while empty, which can damage the magnetron.
Not that I'm optimistic, but the first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Otherwise it likely needs a new magnetron.
Apr 06, 2008 | Microwave Ovens
Cell Phones Logo
27 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
