Question about Element Televison & Video
I HAVE AN ELEMENT TYV MODEL # ELEFW195. WHEN I TURNED THE STATION THE SOUND WENT OFF. I HAVE A PICTURE BUT NO SOUND. HOW DO I FIX IT?
Ecollier2012
  • 3459 Answers
SOURCE: Sound but no picture
Common problem - Its most likely the HVG on this model. www.TvRepairKits.com has instructions on how to get it fixed.
Posted on Apr 18, 2009
Axle80
  • 73 Answers
SOURCE: Element electronics LCD, was on for several hours
Typically this failure is due to the backlight inverter going out. On this model of tv there were two runs with different parts. Open the back of the tv and open the control box. If you see a large black circuit board on the top, replace that one. If its tan then you need to take out the control box and remove the black plastic backing. If you're looking at the back of the tv the inverter will be on the left side of the control box. Its a long skinny board that has 8 black metal squares on it. Good luck and be careful.
Posted on Mar 21, 2010
budmrtn
  • 11361 Answers
SOURCE: Element 32" LCD HDTV 4
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Apr 25, 2011
  • 33326 Answers
SOURCE: picture went black
Likely power supply failure, especially with the bad smell
Posted on Sep 10, 2012
gopakumarg43
  • 73691 Answers
SOURCE: I'm trying to find QR code for element TV model
QR code should be at its back cover. Check it.
Gopakumar Gopalan Google
Posted on May 05, 2014
I have a Vizio V037LF 37" flat screen LCD tv. The picture went out but there is still sound. There is no backlight. I did the the flashlight test but cannot see anything.
It is likely the T-con PCB is at fault, but that is just a guess without doing testing, it is about $200 for the part sure you want to guess on this or just replace the TYV and no worries.
Oct 21, 2016 | Vizio Televison & Video
I'm trying to find the ip code for an element model elefw195?
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
Apr 02, 2016 | Element Televison & Video
No sound, help! My Element flatscreen television model #ELEFW195
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Jan 26, 2015 | Element Televison & Video
What settings do I adjust to fix the volume as I barely hear sound on my element ELEFW195
Go to settings look for sounds click sounds and it should say volume click it all your volume control should show up then turn all your volumes up and hit save but remember hit save or it won't work
Jan 26, 2015 | Cell Phones
Picture went black
Sep 10, 2012 | Element Electronics FLX-3211B 32 in. LCD...
Element electronics LCD, was on for several hours picture went blank, sound is still perfect. 12 hours later still no picture when turned on, great sound though.
Mar 14, 2010 | Element Electronics FLX3210 32 in. LCD TV
Apr 17, 2009 | Philips 55PW9363 55" Rear Projection...
Picture stopped, same pic stayed on for a while, sound went dead
Don't know how I did it. Shut tv off and left it off for awhile put it it back on and picture and sound were OK. Thank you for your concern.
Apr 05, 2009 | Hitachi 51F59 51" HDTV Projection...
Televison & Video Logo
Top Element Televison & Video Experts
Joseph Hoffmann
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
