Pmd103cmtftlcd dvd player does it have a manual/external audio output setting
2 Suggested Answers
SOURCE: Pmd103cmtftlcd with dvd does this have an external manual audio output setting
If no analog audio outputs the optical is it you have to go thru a receiver with an optical in using a to link fiber optic cable
Posted on Apr 25, 2017
Apr 24, 2017 | Televison & Video
No sound when using an external source ie DVD player through an hdmi cable but the sound is fine when just using the TV
May be its not the fault of the TV. Check the hdmi audio setting of the DVD player. Change the player audio output format setting from bitsream to PCM. hope you will get the audio.
http://electro-medical.blogspot.com/
Nov 07, 2015 | Televison & Video
I have a th-42px500u tv i have no sound on tuner output on all channels just picture. I get sound on all other outputs except tuner. I have no dvd or game or cable box connected. Im just have a regular...
Could be tuner, could be settings on the audio menus like external audio or alternate audio. If you checked all these and If it is more than a year old, buy a $40 tuner converter and use external. Not worth fixing. Tuner problems are seldom simple.
Oct 24, 2013 | Televison & Video
Sound is not working
You are not real likely to find a service manual for this brand--
1. check to see if you have sound when using a DVD player connected to the rear inputs---this will rule some things out.
2. check to see if for whatever reason the speakers are switched to off= look in the main and audio menus.
3. Look to see if it has a hookup for external versus internal speakers it is not set to external.
4. If the set has a headphone jack on it---do you have sound there?
Failing, you likely have a audio output issue in the audio circuit of the set.
Dec 07, 2012 | Dynex Televison & Video
2003 Chrysler Town & Country DVD Player doesn't output picture to screen, audio on right side only.
The cost to repair it will cost you more then to just buy a used one from a auto wrecker.
Oct 19, 2012 | 2003 Chrysler Town & Country
Can I fix a external DVD players to aux and how
The unidentified DVD player's manual prescribes its audio connection. If it has a 2-channel analog audio output connect IT to Aux.
Aug 08, 2011 | LG LXD5230 System
I'm trying to set up my Onkyo HT-r380 receiver (which came in the HT-S330 home theater system). I can get AM and FM radio to play on all the speakers. I can not get sound from my XBOX 360. The 360 is...
I looked at the manual and they provided the following settings.
To listen to audio received by the HDMI IN jacks through your TV's speakers:
  • Set the "TV Control" setting to "On" (? 37) for an p-compatible TV.
  • Set the "Audio TV OUT" setting to "On" (? 36) when the TV is not compatible with p or the "TV Control" setting to "Off".
  • Set your Blu-ray Disc/DVD player's HDMI audio output setting to PCM.
  • To listen to TV audio through the AV receiver, see "Connecting External Components" (? 17).
Jul 19, 2017 | Audio Players & Recorders
My marantz DV 9500 doesnt output digital signal for audio cd anymore but outputs audio for dvd,sacd,dvd audio. Does it need servicing
Make sure your playing componet like CD player have a digital output socket. Connect this to a digital port on the amp witk a single RCA or Optical cable if output available on CD. Make sure the digital assingment in amp is set for cd function and corresponding input(example cd plyer connected on dig 4 input on amp, press menu, setup, assignment, go to cd player, make sure setting on dig 4 or change input to dig 4, go to next component to memorise setting.and exit, see manual to assist you) if still no sound take dvd cable for instance that is working and put that in dig 4 port. if that works check in cd player that settings spdif/raw/pcm is correct one for yor digital output if still no sound soun pc board faulty.
Aug 11, 2009 | Marantz DV-9500 DVD Player
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
