Question about Toshiba Televison & Video
Toshiba 46XV645U will not power on
Turned TV off in the middle of the afternoon. Returned a couple of hours later and it will not power up. No lights, no noise, just will not respond. There has not been anything unusual happen, no storm or anything. Changed to a new electrical outlet, tried another remote, tried turning it on with the button on the side of the TV.
snakehead
  • 1074 Answers
SOURCE: TV does not turn on; red light blinking.
your problem is a more technical problem you will need a tech to look at your set if you are not a tech you wont be able to do it your self. contact a tech to repair your set the problem is in the power supply or related circuit.good luck.
Posted on May 02, 2007
dodgecharger
  • 254 Answers
SOURCE: LCD TV WONT POWER ON
A dead condition usually indicates one of the following: Open fuse (often internal, and usually pops due to other circuit defects). Short (overload condition) in the circuitry. Failure elsewhere in the circuitry. Most modern electronics have some logic circuitry, and if there is a section of the circuit not working, the logic circuit keeps the set from coming on at all.
First, if your power cord plugs into the set, check that it is properly connected. If you can get into the internals, find the fuse, check it, replace with an exact or near exact size.
If problems are beyond the simple, technical expertise will be required to nail down and fix the problem.
Posted on Nov 28, 2007
SOURCE: My tv Wont Turn On
My 32" hyundai LCD TV will not turn on. The power lead is ok the on / off switch on the side turns the red stand by light on and off. I am unable to get the LCD TV off stand by. I have tried the the stand by button and this does not do anything. Can anybody help.
Posted on Jun 23, 2008
SOURCE: tv wont turn on
I had the same problem and took it apart. Before the repair there was no "click" when I pushed the button, a clue to the problem. The on-off button on the front pushes a weakly made angle piece of plastic inside which had broken. The plastic piece in turn is supposed to push an internal switch which is offset to one side.
I used epoxy (Araldite) to repair the broken plastic angle piece, but it still looks weak to me so I switch the tv off at the wall and leave the on-off button alone (though it does work now).
Opening the case requires some knowledge and care, and can be dangerous. It may void the warranty so be careful or give it to a qualified repair person.
Hope this helps!
Posted on Jan 09, 2009
  • 7 Answers
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
Posted on Aug 31, 2009
I have no power for my 2010 Toshiba regeza 47 inch Model # 46XV645U SERIAL # A01433T76542K1
Check your power board for any defaults or change the power board all together.
Nov 14, 2016 | Toshiba 46XV645U LCD TV
Toshiba regza 46xv645u won't turn on and clicks
the clicks is it trying to come on an is crowbarred off
an error condition in the power
many just over heat an the large capacitors in it short out
it will take isolation of circuits to find the exact module . likely the power module . that you might find on ebay.
Jul 25, 2014 | Toshiba 46"" regza 46xv645u 1080p 120hz...
Cant get tv to stay turned on ,,,after about 10 secs,,,it turns itself off
if you know some basic electronics repair just proceed to the power supply board the look for any bulging electrolytic capacitor ,sometimes not bulged but if test it with capacitance checker it was leak and need replacement.
Aug 29, 2012 | Toshiba 46XV645U LCD TV
Toshiba 46XV645U Shadow Effect Problem
thats usually caused by a flex tab bond on the panel itself especially if the screen appears slow motion in that area.
Aug 07, 2012 | Toshiba 46XV645U LCD TV
TV NOT WORKING
TURNED TV ON AGAIN 2 DAYS LATER AND IT WORKED.
Jan 18, 2009 | Sony Televison & Video
Problem with Projection TV
This set is very common for the str typr power regulator to go out on it. Its not a consumer replaceable part. Please find a trained tech to assist you with this repair. Good Luck
Aug 09, 2006 | Toshiba TZ55V61 55" Rear Projection...
Televison & Video Logo
65 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
