Question about Music
Gt10 pedals not working - Music
It suddenly stoped working. Doesn't turn on anymore. What can it be?
Julio, If you already changed power supply and no success, it is probably a bad solder joint on board. I will post a link below that may help or you can try a forum.
Feb 19, 2016 | Roland Boss Gt-10 Guitar Effects Processor...
Patch not saving,write button is not working from the day i bought.i bought is 2nd hand.plez help
If you buy a second hand, it may have been damaged in mini switch (tact switch) under the WRITE button. You need to replace the tact switch. Easy and inexpensive, you can do yourself, only with a little knowledge of soldering
Tact Switch:patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-1.jpeg
You may also try the FACTORY RESET.
Restoring the GT-10 to the settings made at the factory is referred to as a "Factory Reset."
Not only can you return all of the settings to the values in effect when the GT-10 was shipped from the factory, you can also specify the range of settings to be reset.
If you do this"Factory Reset", all the setting on user memory (that you create) will be erased, so backup your setting before doing this steps.
For more detail on "Factory Reset", read the GT10 user manual:
Sep 16, 2015 | Roland Boss Gt-10 Guitar Effects Processor...
Fix a Boss GT-10 broken input jack
what is your question?
if not working, you have to open the device and find out where it is not connecting (broken solder joint? bent or worn out contacts? wire off?) and repair. or if beyond repair, order a new part.
Feb 22, 2013 | Roland Boss Gt-10 Guitar Effects Processor...
Non-working Boss GT 6 project for my kids.
Request the schematic diagram directly from Roland.
Dec 08, 2017 | Roland Boss Gt-10 Guitar Effects Processor...
Headphone output safety warnings on guitar effects
There is a small chance it "could" but more likely you would just overdrive the input stage to clipping.
You can try it- you need to keep the viltage input to the amp at 1 volt peak to peak or less, or you run the risk of clipping. You should use shielded cable, as you may also pick up other noise along that cable.
Mar 28, 2012 | Roland Boss Gt-10 Guitar Effects Processor...
Check for intermittent connections of cables. The vibration of turning it off and on MAY be fixing a poor connection. Verify the problem exists using new cables. Intermittent problems are tricky to find so we have to do tests to narrow the possibilities.
Apr 25, 2011 | Roland Boss Gt-10 Guitar Effects Processor...
On u47 a=cl +mod b=od on the screen the sound comes out one headphone speaker a lot more louder than the other all the leads are ok the headphones are ok and the balance is set in the middle is this normal...
This is far from normal. What may be the problem is a component on the circuit board itself. You may have to take this to someone who has a multimeter to test and see which one it is (this may take a while, since there are a LOT of small components). If you don't want to (or have the money to) do that, you can just set the balance to the opposite side of the louder speaker until it sounds even out of both channels. Eventually, though, something will have to be fixed.
Hope that helped!
Feb 10, 2011 | Roland Boss Gt-10 Guitar Effects Processor...
How do i connect the boss gt 10 to a fender blues deluxe amp and bypass the amps preamp
You can plug the output of the gt10 into the "power amp in" jack of the Fender. This bypasses the preamps in the Fender but uses a buffer amps in the Fender to drive the power amp. Please note that the reverb is STILL in the circuit when you do this. You can turn the reverb to zero if you wish to disable it.
Jun 09, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Music Logo
18 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
