Question about In Microwave Ovens
The oven door won't open. It happened when it wasn't being used. How do I get the door to open?
Someone suggested that I should shut off the switch at the box in the basement and then reconnect. This did not work. I still can't open the oven door.
    Master:
  • 340 Answers
If it is a self cleaning oven try running it thru the clean cycle to see if the door will unlock at the end of the cycle.
Posted on Apr 24, 2017
My GE Microwave Model JKP90SP4SS will not shut off, even with no time programmed and cooking is done. The only way to stop operation is to open the door or shut off the breaker.
This kind problem is usually associated with the door micro switches. What happens is the switches are supposed to prevent operation when the door is open and other things. When one fails, often the oven will run with the door open or closed. There are a number of these micro switches inside and they protect the user from certain unintended actions or combinations of actions. This usually happens with well used ovens. There are extremely dangerous voltages inside a microwave over, even when not connected to power. Find a tech who knows these things.
Jan 07, 2017 | GE Microwave Ovens
Magic chef MCD1611ST microwave, the display lights up, the time and powerlevel can be set, the light works when the door is open but when i hit start everything shuts off. Any suggestions?
There are a lot of possible causes, but I'd look at the door switches first, and the wiring connectors to them. Make sure the contacts on all the switches are opening and closing.
Nov 19, 2016 | Magic Chef MCD1611ST Microwave Oven
Won't shut off
You may have a problem with a door switch or door switch mount, or there may be a shorted relay on the control board, which can easily be repaired.
Our help file on door switches is here, and the Advantium 120 service manual is here.
You can order GE parts from the Pros here.
Jun 06, 2013 | GE Advantium 120 Convection/Microwave Oven
Jennair Microwave Shuts Off after 3 seconds
This is usually a defective or loose bottom door switch or that switch's mount is loose, misaligned or broken.
It's usually caused by opening the door while it's cooking instead of hitting "stop" first) or slamming the door or both.
My help file on door switches is here.
May 19, 2013 | Jenn-Air JMV8186AA Microwave Oven
Microwave won't start
I have the same problem. Is the light still on inside the microwave? Mine is on and the microwave thinks the door is not shut. I took the top off of the microwave and the latch needs to push down on a switch once shut. The latch was reaching the switch, but I think some spring in the door, pushing the latches down, has broken since it reaches the switch when closed but there isn't any downward force to flip the switch.
I am trying to figure out how to repair the latch but if your light is on when you "shut" the door, you may have the same problem.
Aug 23, 2012 | Cuisinart CWM-100 Microwave Oven
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
When opening microwave door, microwave is running
Your microwave oven's door interlock switch has failed. This is the switch that is supposed to shut off the microwave when the user opens the door.
Since parts for small appliances are unavailable (replacement parts are only available for major appliances), you'll have to either live with it or try to fix it by finding a similar microwave in someone's trash, and using that unit's door interlock switch...
Possibly a popsicle stick (or other safely non-conductive article) can be pushed into the appropriate
contact point?
Sep 10, 2011 | Frigidaire Microwave Ovens
GE Microwave Oven would not shut off even when the door was opened. We unplugged it and plugged it in later and now it seems to be OK. What happened?
Hi, the contacts in the micro switch or relay proberbly fused together. Do not open door if is still on unless you want to cook yourself
Aug 04, 2009 | Microwave Ovens
Microwave comes on on its own. What can be the problem?
I suggest you see a repairer but until then when ever it's not in use leave the door OPEN
Kind Regards,
J Howard
FixYa Operator
Dec 28, 2008 | Frigidaire FMV156DC Microwave Oven
JVM1490 Low fan noise when not in use shuts off when door is open turns back on when door is closed?
it sounds as if your door switch is out of line. If this only happens when you close the door you may want to check they switches on the inside. one of them is either bad or you just may need to line it back up.
Jul 08, 2007 | GE JVM1490 Convection/Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top In Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
