Question about Troy Garden
After using the Troy Bilt Pony and turning off, it will not start only turns over
  • 376 Answers
SOURCE: Just bought a 10 hp troy bilt chipper used. When
As LeeatCSEb said, It's your float needle and seat not shutting off the flow of gas when your carb bowl is full. Have your needle and seat replaced. Dwain
Posted on May 18, 2009
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
SOURCE: need a owners manual for troy bilt 17.5 hp 42 inch
HOW TO CHANGE A BELT ON
  • Troy-Bilt 17.5-HP Manual 42" Riding Mower
  • Posted on Apr 19, 2010
    al_kupchella
    • 843 Answers
    SOURCE: broken pull cord on my manual start Troy-bilt Pony
    It's definitely do-it-yourself in that no special tools or skills are required, but it can be a little tricky. You can see that the the recoil starter is in an assembly which is spot welded onto a metal cover. You have to remove the entire metal cover that includes the recoil starter. There may be 6 to 10 screws to remove to do that. When you get it off you will see a plastic spool that holds the cord. This spool is probably held in place by a couple of metal tabs that are bent down. Bend those tabs up with pliers. Underneath the spool is a spiral spring that provides the recoil. Take careful note of how this all goes together. Buy a new cord (available by the foot at a hardware store) and wrap it around the plastic spool. Use a piece of tape to hold the end of the new cord above the spool so you can thread it through the hole in the metal housing later. Put the spring and the spool in place, then wind the spool to put tension on the spring - about 5 turns in the direction that would push the string out through the hole. Once you have the spring "wound up" remove the tape and thread the end of the cord through the hole. Now bend those metal tabs back down. Put the handle on the cord end (or tie a knot) to keep the spring from pulling the end of the cord back through the hole. Reassemble the rest and you are in business.
    Posted on Jun 15, 2010
    • 183 Answers
    SOURCE: troy bilt pony will not start. replaced 20 amp fuse and battery
    OK -- Here's what to do:
    TROY-BILT PONY LT CRANKING CIRCUIT TROUBLESHOOTING
    NOTE 1: The following tests are to be made with the parking brake applied and the PTO disengaged unless otherwise specified.
    NOTE 2: These tests need only be made until the cause of the problem is located. The entire process need not be completed if the problem has been resolved.
    NOTE 3: Refer to the wiring diagram below for understanding of all tersts.
    NOTE 4: Wiring Diagram references to Key switch A1 and L terminals refer to the same terminal.
    1. With all circuits connected normally, connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the battery positive terminal. The voltmeter should read at least +12.6 VDC.
    a. If NO, go to step 2.
    b. If YES, go to Step 3.
    2. Connect a DC voltemeter directly across the battery. The voltmeter should read at least 12.6 VDC.
    a. If NO, charge or replace the battery.
    b. If YES, check and repair/replace the following items as required, then repeat Step 2 test. If YES on retest, go to Step 3.
    -- battery negative cable condition
    -- battery negative cable connections at the battery
    -- battery negative cable connections at the tractor frame
    3. With all circuits connected normally, connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the key swttch "B" terminal (Circuit #97 - red/white wire). The voltmeter should read at least +12.6 VDC.
    a. If NO, go to step 4.
    b. If YES, go to Step 8.
    4. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the starter relay BAT terminal (Circuit #94 - heavy red wire). The voltmeter should read at least +12.6 VDC.
    a. If NO, check and repair/replace the following items as required, then repeat Step 4 test. If YES on retest, go to Step 5.
    -- battery positive cable condition
    -- battery positive cable connections at the battery
    -- battery positive cable connection at the starter relay
    b. If YES, go to Step 5.
    5. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the fuse holder BAT terminal (Circuit #92 - red wire). The voltmeter should read at least +12.6 VDC.
    a. If NO, check and repair/replace the following items as required, then repeat Step 5 test. If YES on retest, go to Step 6.
    -- Circuit 92 wire condition
    -- Circuit 92 wire connection at the starter relay
    -- Circuit 92 wire connection at the fuse holder
    b. If YES, go to Step 6.
    6. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the fuse holder protected circuit terminal (Circuit #97 - red & white wire). The voltmeter should read at least +12.6 VDC.
    a. If NO, check and repair/replace the following items as required, then repeat Step 6 test. If YES on retest, go to Step 7.
    -- 20A fuse condition
    -- fuse holder condition
    -- fuse holder wire connections
    b. If YES, go to Step 7.
    7. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the key switch "B" terminal (Circuit #97 - red & white wire). The voltmeter should read at least +12.6 VDC.
    a. If NO, check and repair/replace the following items as required, then repeat Step 7 test. If YES on retest, go to Step 8.
    -- Circuit 97 wire condition
    -- Circuit 97 connection at fuse holdser
    -- Circuit 97 connection at key switch
    8. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the key switch "S" terminal (Circuit #80 - orange wire). With the key held in the START position, the voltmeter should read at least +12.6 VDC.
    a. If NO, check and repair/replace the following items as required, then repeat Step 8 test. If YES on retest, go to Step 9.
    -- key switch assembly
    b. If YES, go to Step 9.
    9. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the parking brake switch Circuit #80 terminal (Circuit #80 - orange wire). With the key held in the START position, the voltmeter should read at least +12.6
    VDC.
    a. If NO, check and repair/replace the following items as required, then repeat Step 9 test. If YES on retest, go to Step 10.
    -- Circuit 80 wire condition
    -- Circuit 80 connection at key switch
    -- Circuit 80 connection at parking brake switch
    b. If YES, go to Step 10.
    10. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the parking brake switch Circuit #70 terminal (Circuit #70 - orange & black wire). With the key held in the START position, the voltmeter should read at
    least +12.6 VDC.
    a. If NO, check and repair/replace the following items as required, then repeat Step 10 test. If YES on retest, go to Step 11.
    -- parking brake switch assembly mounting and adjustment
    -- parking brake switch assembly condition
    b. If YES, go to Step 11.
    11. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the PTO switch Circuit #70 terminal (Circuit #70 - orange & black wire). With the key held in the START position, the voltmeter should read at least +12.6
    VDC.
    a. If NO, check and repair/replace the following items as required, then repeat Step 11 test. If YES on retest, go to Step 12.
    -- Circuit 70 wire condition
    -- Circuit 70 connection at parking brake switch
    -- Circuit 70 connection at PTO switch
    b. If YES, go to Step 12.
    12. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the PTO switch Circuit #60 terminal (Circuit #60 - orange & white wire). With the key held in the START position, the voltmeter should read at least +12.6
    VDC.
    a. If NO, check and repair/replace the following items as required, then repeat Step 12 test. If YES on retest, go to Step 13.
    -- PTO switch assembly mounting and adjustment
    -- PTO switch assembly condition
    b. If YES, go to Step 13.
    13. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the starter relay Circuit #60 terminal (Circuit #60 - orange & white wire). With the key held in the START position, the voltmeter should read at least
    +12.6 VDC.
    a. If NO, check and repair/replace the following items as required, then repeat Step 11 test. If YES on retest, go to Step 14.
    -- Circuit 60 wire condition
    -- Circuit 60 connection at PTO switch
    -- Circuit 60 connection at starter relay
    b. If YES, go to Step 14.
    14. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the starter relay MOT terminal (Circuit #93 - heavy red wire). With the key held in the START position, the voltmeter should read at least +12.6 VDC.
    a. If NO, did the relay make a single heavy "click" noise?
    1. if YES, replace the starter relay and repeat Step 14 test. If YES on retest, go to Step 15.
    2. If NO, connect a DC voltmeter DC voltmeter black (NEG) lead to the battery negative terminal and the red (POS) lead to the starter relay frame. With the key held in the START position, the voltmeter should read a maximum of +0.1 VDC.
    a. If YES, replace the starter relay and repeat Step 14 test. If YES on retest, go to Step 15.
    b. If NO, check and repair/replace the following items as required, then repeat Step 14 test. If YES on retest, go to Step 15.
    -- starter relay mounting
    b. If YES, go to Step 15.
    15. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the starter motor BAT terminal (Circuit #93 - heavy red wire). With the key held in the START position, the voltmeter should read at least +12.6 VDC.
    a. If NO, check and repair/replace the following items as required, then repeat Step 15 test. If YES on retest, but the starter motor does not engage, go to Step 16.
    -- Circuit 93 cable condition
    -- Circuit 93 cable connection at starter relay
    -- Circuit 93 cable connection at starter motor
    b. If YES, but the starter motor does not engage, go to Step 16.
    16. Connect a DC voltmeter black (NEG) lead to the battery negative terminal and the red (POS) lead to the starter motor frame . With the key held in the START position, the voltmeter should read a maximum of +0.2 VDC.
    a. If NO, check and repair/replace the following items as required, then repeat Step 16 test. If YES on retest, but the starter motor does not engage, go to Step 16b.
    -- starter motor mounting to engine
    -- engine mounting to tractor frame
    b. If YES, but the starter motor does not engage, replace the starter motor.
    REFERENCE PART NUMBERS PER WIRING DIAGRAM:
    Note that your specific tractor may use differnt part numbers. You can obtain a Parts List specific to your tractor online, at no charge, from Troy-Bilt at www.troybilt.com -- your full model number and serial number are required.
    Key Switch 725-04228 (common alternatives are 925-04227B & 925-04659)Parking Brake Switch 725-1657A (common alternative is 725-04363)
    PTO Switch 725-1657A (common alternative is 725-04363)
    Starter Relay 725-04439
    Also note that the starter motor is an engine manufacturer supplied part.
    Posted on Jul 20, 2012
    Troy Bilt pony will not start
    no fire , sounds like your having a problem with one of the safety switches on mower deck ckt look under tractor but over mower deck for a loose or hanging wire bet it goes to a switch ?
    Nov 13, 2013 | Troy Garden
    Tines wont engage on my troy built pony. How can i fix it?
    The lever for the tines moves easily? Is there an adjustment on the linkage that may need tightening?
    May 11, 2012 | Troy-Bilt Pony Garden Tiller
    Need gasket carbereter kit
    I have been trying to help you. It appears that the "pony" model has submodels as well I will send you this link and please post back with which model is yours. Model numbers are the BIGGEST help I get, because I can research this machine all day and not have the correct carburetor for your exact model. Here are the current Troy Bilt "Pony" Tillers for sale on the net.
    http://www.bing.com/shopping/search?q=Troy+Bilt+Pony+Tiller&FORM=HURE
    Again, please reply. I will get your reply and continue to assist you. Thanks!
    Jul 04, 2011 | Troy-Bilt Pony Garden Tiller
    My Troy riding mower Pony will not start .. Turn the key and nothing not even a click. I just replaced the ign because of this issue and it still nothing
    Have you replaced the battery or the starter? I would start with the battery because if you do not keep the battery warm over the colder months it will drain without the ability to hold a charge.
    Aug 13, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
    Troy Bilt Pony won't start
    Try taking the shroud off of the motor and and cleaning the magnets on the fly wheel. Also clean the two little prongs next to the fly wheel. You can also clean the end of the spark plug cable that hooks onto the plug. I use fine sandpaper or emery cloth.
    Good Luck
    roundo4
    Sep 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
    Jim
    May 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
    Tilller will not run
    Get the model # and serial # off of the sticker. Got to the Troy Bilt site and use the owners manual link. Need to leave off the last 3 numbers of the model #.
    If that site does not have the manual, I've found them on the MTD site. I enter only the first 2 numbers of the model # and then hunt for my manual from the list.
    If all else fails, you can call Troy Bilt at their # provided on the site.
    Hope this helps.
    Apr 29, 2009 | Troy-Bilt Pony Garden Tiller
    Troy bilt pony left side tine assembly fell off
    sounds like the shaft is either bent,or the inside diameter is worn and the shaft tube needs to be replaced.
    Apr 23, 2009 | Troy-Bilt Pony Garden Tiller
    Garden Logo
    24 people viewed this question
    Top Troy Garden Experts
    Matt Olenzek
    Matt Olenzek
    Mike Squire
    Tim Whalen
    Are you a Troy Garden Expert? Answer questions, earn points and help others
