Question about Samsung Washing Machines
I have a Samsung Top Load Washer Model WA56H9000A/A2 error code PE.
I have seen some sites list Samsung error code PE as the Clutch Motor, and LG models list error code PE as a pressure sensor. I just would like to verify what this error code is before I go out to purchase parts.
4 Suggested Answers
canbruce75
  • 1776 Answers
SOURCE: Error code LE on front load LG washer
This is a motor fault code. Sometimes it can be just a communication error, in which case you can try unplugging the machine for 20 minutes and see if it clears the problem up. More likely it is a fault in the motor itself. The most likely culprit would be a defective hall sensor. I will attach a photo of the sensor for you to see what it looks like. To access and replace the hall sensor, you have to remove the rotor and stator at the motor. Before going to this trouble, try the unplugging thing first and also check the connector on the main control board. It is the red connector next to the heat sink2.gif. Using a multimeter, check that the board is receiving a signal from the sensor. Hope this helps and best wishes.
Posted on Sep 02, 2009
Daniel S
  • 4323 Answers
SOURCE: I have a Maytag front load Washer Model
Hi
There is only one Analog Pressure Sensor Switch Part no. W10156252, another one that it has is the water level switch (part no W10415587). I believe you are talking about the first one as that is what error code F35 means (ANALOG PRESSURE SENSOR FAILURE). Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 17, 2011
  • 1010 Answers
SOURCE: we have a samsung top load washer model wa5471 that sets a PE error code . I looked up code in tech. info. said to check clutch motor ; replaced motor still have same problem . looking for more help.
The code stands for pressure or fill level, check this sensor
Posted on Mar 28, 2013
I have a top load Samsung washer I just bought a few months ago. Model #WA45H7000AW/A2 serial #OBHESAUH21879X It is one on recall and I can't get through to report it.
if there is a problem ringing up your local service agent, go in and talk with them
after all they will be the ones doing the recall fix
Nov 04, 2016 | Samsung 4.5 Cu Ft Capacity White Top Load...
Samsung washer PE error code.
What kind of washer? front load? top load? model?
Oct 14, 2016 | Samsung Washing Machines
Washing machine LG TR9103AEP IE error what does it mean ?
LG Top Load Washer-Understanding Error Codes - YouTube
? 2:17
www.youtube.com/watch?v=ZdoJVqFKye4
Sep 17, 2013 - Uploaded by ExperienceLG I have LG Washing machine and I tried to start it and came up with PE Error code and I ... I Can see IE OE and other error codes But Not PE.
Aug 04, 2015 | LG Washing Machines
PE error (Clutch Motor Error) how is this repaired?
NOT SURE ABOUT UR MODEL BUT THE CLUTCH ASSEMBLY IS PRETTY BASIC AND COMMON, U MAY NEED TO REPLACE IT, ARE U HAVING SPIN PROBLEMS ( SLOW SPIN OR NO SPIN) OR LEFT WITH WET CLOTHES NOT SPINNING DRY.
May 18, 2015 | Samsung WA5471AB 4.7 Cu. Ft. Top Load...
I get an error code PE on Samsung washer WA5451washer
PE error code is a pressure sensor code, and more than likely the sensor will need to be replaced. Try unplugging the unit for about 5 minutes and see if it will clear it out. If not, will need to replace pressure switch and hose (switch looks like a little UFO under the console, pretty easy job.
Nov 11, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Lg top load washer e6
E6 is listed by Samsung as :- Water temperature rising/falling too quickly. Check thermistor.
Oct 21, 2012 | LG WFT1071TP Top Load Washer
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
