Question about Maytag Ovens
Maytag gas oven MGR5750ABA
The oven door was accidentally locked when the cleaning option button was pressed accidentally. The cancel button did not stop the process but the bake button did. The next morning, when the oven had cooled, we gently tried unsuccessfully to open the oven door again. The digital screen on the oven indicated the same "dr" message as it did the night before. Please let us know if there is any way to open the door? (Last night's dinner is still inside--though uneatable.) Thank you.
reg501
  • 413 Answers
SOURCE: self-cleaning gas oven
Door lock motor has probably failed.....Self clean on many
ovens can be a self destruct mode. Door latch motors, sensor
probes and even the electronic controls can be destroyed by
this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
Posted on Jun 03, 2008
rylee_smith
  • 8619 Answers
SOURCE: I accidently pressed self clean instead of boil on my oven
Hi
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
*On -some- Frigidaire built ranges, the switch is located behind the right hand side panel and activated by the right hand door hinge. On this model, the side panel may need to be removed to access a malfunctioning door switch.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Apr 27, 2009
  • 39 Answers
SOURCE: Whirlpool oven door won't open.
You can try unplugging the over for a while and seeing if that helps. But if that doesn't help you will have to let the oven complete the cleaning cycle in order to regain use.
Posted on Jun 23, 2009
milten1
  • 1304 Answers
SOURCE: I turned on the self cleaning process let it clean
since i dont know your model try this
unplug the range for 30 mins
let the memory clear
and then plug it back in
this works for several differant manufacturers
Posted on Oct 13, 2009
SOURCE: set oven to clean, get flashing door indicator lig...
If this is an Electrolux oven then F9 relates to micro-processor resets itself.To get this to reset fully its reccomended that you disconnect the unit from the electric supply and then reconnect then retry.
Hope this helps
Posted on May 12, 2010
I went to clean my oven and it locked I pressed cancel the door opened but my oven doesn't work when I hit bake locked signal comes up what do I do
Your oven got locked by a hook that gets initiated when the "Clean" button\option is depressed. Even though you hit cancel and the door opened, it is possible the hook didn't completely recluse back into it's housing.
Might I suggest trying to hit clean and let it take it's course, and try to verify the unit DOES heat up during the cleaning process? This may be the only option you have without calling out for a service call.
I really hope this helps.
Aug 16, 2017 | Ovens
Oven door is locked with food in it how to unlock asap
Hi , Anon !
My name is Ashlynn .
If your oven is locked , here's some ways you can unlock it :
  • 1 Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • 2 Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3 Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4 Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    But it seems you have food inside so ,
    Press cancel on the cooking cycle , and let it cool to room temperature , and then try to open your oven .
  • Feb 25, 2015 | Maytag Ovens
    Accidentally hit the oven clean button while baking
    Hello there.
    From the manual I got
    To Stop Self-Clean any time:
    Press UPPER OFF, LOWER OFF or OFF/CANCEL. If the oven
    temperature is too high, the door will remain locked. It will not
    unlock until the oven cools
    Hope it helps/
    Sep 23, 2014 | Whirlpool RBD305PD Electric Double Oven
    We used the self cleaning option and now we cannot get the oven door open. The lever is stuck in lock mode. Can you give suggestion?
    IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
    The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock.
    IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature)
    Thank you and thanks for using fixya
    Sep 29, 2010 | Jenn-Air JGW8130A Electric Single Oven
    How do we unlock the oven door! Accidentally pushed a button in front. We have no manual or SS#. Oven was in house when we bought it. We unplugged it to turn off and was able to open the door. Please...
    The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can un-lock (safety feature).
    Good luck with this!!
    Aug 18, 2010 | GE Profile JTP18 Electric Single Oven
    Maytag double oven is locked and won't open
    Hi. Has a fault code been displayed and a continuous beeps? press and hold the cancel & cook & hold buttons together for about 3seconds then door should open.
    Hope this helps.
    David
    Sep 13, 2017 | Maytag MEW6630D Stainless Steel Electric...
    Door locked after cancelling self clean option
    Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
    If you need more assistance let me know.
    Mar 29, 2009 | Ovens
    Oven is locked
    press Clean again and add time the quickly open the oven . Before it lockes in clean mode it unlocks soo yea hope this helps.
    Feb 22, 2008 | Maytag CWG3600A Gas Single Oven
    Cleaning the over
    Try pressing and holding the cancel button for at least 5 secs. Wait a few mins. Something different should display on the display panel. The door should unlock after a couple of minutes.
    Dec 25, 2007 | Kenmore 30172 / 30174 / 30179 Gas Single...
    Ovens Logo
    Top Maytag Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    Mack Baxter
    Are you a Maytag Oven Expert? Answer questions, earn points and help others
