Question about Boating
Johnson9.9 outboard mod. No.1dr78m - Boating
What parts are needed to make manuel start outboard to electric? Evinrude 30 hp.1986 mod#E30RCD
Evinrude MIGHT sell a conversion kit call a reputable dealer.
Jul 24, 2017 | Boating
How do you find the correct number of teeth on the starter motor gear to match your fly wheel on the outboard motor?
I'm not entirely familiar with that model off the top of my head. However, the flywheel for that model seems to be 0583001 which is a 74 tooth. With that said, I make no promise but https://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1988&hp=20&model=E20CRCCA&manufacturer=Evinrude§ion=Electric+Starter+%26amp%3B+Solenoid matches that flywheel. Hope that helps some, maybe guides you in the right direction.
Sorry that link didn't go through as I had planned.
The starter drive assembly for the 74 tooth is 321648 — DRIVE ASSY., 11 TOOTH. USE ONLY WITH FLYWHEEL P/N 583001 (74 TOOTH). The starter shows to be 5376 - Outboard Starter, Johnson Evinrude, 18-40HP
Apr 08, 2017 | Boating
No spark at plugs on mercury mod. 650 outboard
Please Tell Me The Serial No Of This Engine
Apr 01, 2013 | Boating
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
Modifying 85h.p.into 140h.p.?
Mate!!!!! To do the mod will cost your more than god has.The entire inlet system is different.The entire exhaust system is different.You may buy all the parts from an outboard wrecker and they will all bolt on.But 1st check the prices for a new powerhead that will bolt straight on.V4 is the motor I think you are talking about.On the 140,make sure the exhaust plate is not about to corrode through.It,s a common problem.Hope this helps
Aug 21, 2009 | Boating
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
