Question about Furniture
ELECTROLUX LFWC18T6LB wine cooler display says ER. On both temperature displays. The cabinet light also flashes.
aborcass
  • 2651 Answers
SOURCE: Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Posted on Mar 01, 2008
  • 218 Answers
SOURCE: wine cooler
Try this website. http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=224777abd6c75c24622a757a6f5ff1ba&q=Magic+Chef+MCWC30MCG&e=1
Posted on Jul 27, 2008
SOURCE: Oster wine cooler (peltier diode)
I called the contact in one post below, and he was VERY helpful. Took all my info, submitted to the division handling this and they overnighted me a check for the entire amount plus tax for the wine cooler to me! Call Jason!
Jason's contact info is:
Jarden Consumer Solutions
2381 Executive Center Drive
Boca Raton, FL 33431
(561) 912-4100
Posted on Oct 02, 2008
SOURCE: electrolux wine cooler ''af'' code flashing
Believe it or not we had the same problem.... The air filter should be changed about every six months but it is just charcoal or baking soda or something like that and is not attached to any sensors. To reset the flashing light, make sure the control panel is unlocked then hold down the on/off and (-) buttons and it will reset.
Good Luck! Elisabeth
Posted on Sep 01, 2009
  • 59 Answers
SOURCE: Magic Chef MCWC8DSCT Wine Cooler
I had the same problem. I fixed the problem by replacing the main cooling fan that is mounted over the electrothermal cooling unit.. Fan can be ordered from RepairClinic.com.
Posted on Sep 02, 2009
Digital temp control does not display when on
Either the compressor is shot or the circuits controlling its operation are no good. Since the display does not light up I am sure it is a controller problem and the module needs replacement.
Nov 21, 2013 | Arctic Air SCW120 Wine Cooler
Magic Chef Wine Cooler Model #MCWC50DBT will not hold correct temperature. Temps fluctuate between about 45 to often 70 degrees F. Also, often get an "EEF" error message.
Mr. Lindquist: We are experiencing essentially the same problem. Have tried replacing the temperature control board without change. Would be interested to know if you get a solution.
Aug 10, 2013 | Haier BC112G Wine Cooler
Instruction manual for dihl wine cooler 32 bottles
i have a dihl 21 bottle dual control wine cooler. the temperature display keeps flashing and won't set, this is now happening with both top and bottom ... how do i fix it
May 18, 2012 | Refrigerators
My wine cooler is not reaching the set temperature. It stops at around 73 and the display flashed AL. Any ideas?
check to see if compressor cycles, if so you may have a thermistor problem which is intergrated with control, replace if you can find part. make sure to check evaporator, see if ice is forming if so you have a leak,or dry evap. you have a leak. repar.
hope this helps.
Aug 14, 2010 | Vintage Keeper Koolspace Wine Cellar
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
Digital temperature display is missing part of the
You are going to have to replace the display. Easy fix even if you are not very familiar with this system
Jan 02, 2010 | Oster 12-Bottle Wine Cellar - Black
Wine cooler does not get cool - fans do not run the light and temperature display do work
if you hear the compressor tun on but not the fan, replace the fan and you may have to defrost the evaporator coils. if the compressor does not turn on either, it's the thermostat, the defrost timer, or a relay on the main board.
Nov 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Electrolux wine cooler ''af'' code flashing
Aug 30, 2009 | Electrolux Refrigerators
Furniture Logo
42 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
