Question about Craftsman Garden
Have craftsman high wheel gas weed trimmer, can't prime gas frm carburetor, replaced gasket on board, still unable to prime gas!
    Loyalty:
    Visited the website for 30 consecutive days.
  • Craftsman Master
  • 1,425 Answers
Replace primer bulb
Posted on Jan 29, 2018
slohry
  • 87 Answers
SOURCE: need parts for craftsman edger/trimmer 275.796432
Here's a link to sears parts website
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Posted on Apr 10, 2009
#1 Taper
  • 1041 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
dontbother10
  • 2220 Answers
SOURCE: Craftsman chain saw only runs short time
Craftsman is made by Poulan.
How old is the saw? Have you checked for split fuel hoses? Change the cc to model number (2.2cc Craftsman is often Model 2200 Poulan) and try to find an IPL http://www.ordertree.com/cms/illustrated-parts-list/9788.html. This will show hose routing. As a last resort you may try the "Chainsaw forum here http://www.arboristsite.com/. These are good guys but you will be flamed for buying a homeowner saw.
Lou
I'd put the filter back on.
Posted on Sep 04, 2009
SOURCE: repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Posted on Sep 05, 2009
  • 41 Answers
SOURCE: Craftsman weed wacker trimmer head won't turn
it could still have the broken peice from the old one inside the seat.take it apart and look inside and inspect the seat where the drive cable enters.
Posted on Apr 14, 2010
Weed Eater Priming
Check out the tubing to the carb. If it is good then the top part of the carb with the check valves is defective. If so, you need a new carb since those suckers cannot be fixed.
Aug 21, 2016 | Craftsman Weed Wacker Lawn Edgers
I push primer on craftsman 32cc weed wacker trimmer and gas just runs out carb all lines are hooked up properly any suggestions
its supposed to,thats where the gas goes when you prime it,hold it up or choke it to start
Apr 17, 2015 | Craftsman Garden
Primer bulb will not prime
Hello Tony Galvan, I had to replace the fuel lines to keep from sucking air when I pressed on the primer bulb. Also, I took the carburetor apart and found the gasket was good by holding it up to the sunlight, no light came through indicating holes in the gasket. Then I took a magnifying glass and looked at the bottom half of the carburetor and noticed that a soft film of what looks like lint from a dryer had accumulated on a screen mesh type of filter. Once I cleaned the debris away, the weed wacker started every time. I pulled with a full choke and partially wants to start. Then moved the choke to half choke and pressed on the throttle fully and pulled, it started! But you must at least hold the throttle close to full until 10 seconds for the engine to warm up. Then move the choke to idle. Hope this helps.
peterjb1
May 29, 2013 | Weed Eater SST25CE Gas Trimmer
My weed eater will run for about 3-5 seconds in the half choke position, but turns off every time. My instructions say to leave it running in the half choke position for about 10 seconds and then push it...
Carburetor. It is always the carburetor 90% of the time on these. There are gaskets and diaphragms in these little carburetors that go bad and periodically need to be replaced. The introduction of ethanol into our pump gas has only hastened this situation. Your carburetor is dying "lean" as they say, and is a result of lack of fuel flow through the idle jet and the high speed jet...probably due to a stiff fuel pump diaphragm and metering diaphragm. They sell a little bag with replacement parts to make it work right again. It is called a G & D kit (gasket and diaphragm). You HAVE to know the manufacturer and the model number of the carburetor to order the right one though.
Aug 13, 2011 | Craftsman 25cc Gas Line Trimmer
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
My Craftsman 32CC weed trimmer wont start. I believe no gas is getting into the carb, becuase if I pour a small amount of gas directly into the carb it starts, but then quickly dies.
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Aug 23, 2010 | Craftsman 25cc Gas Line Trimmer
I have a craftsman weed trimmer, it starts ok, but won't run
Sometimes you can get by with priming it a few times, and letting it
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
When you clean your carburetor and remove the jet screws, count the
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
May 24, 2010 | Garden
My craftsman gas weed trimmer runs but lacks power. Its a gas oil mix and has some screw adjustments. Any help would be great. Edward
Hi Edward,
If the mower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the number of turns it takes to seat the jets from their original position.
May 20, 2010 | Garden
Craftsman weed eater wont run
MAKE SURE YOU REPLACE THE CARB GASKETS. ALSO MAKE SURE YOU ARE USING FRESH FUEL WITH THE RIGHT MIXTURE. COMPRESSION SHOULD BE AT LEAST 90LBS
Sep 24, 2009 | Garden
Garden Logo
43 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
