What does a compression wave look like - Audio Players & Recorders
Why would i have 60 psi in all 3 cylinders. ran great then all at once it started to run bad
anything below 100psi on 2strokes is usless and needs new rings as long as no damage and in tolerance to pistons ! reed valves and crank seals have nothing to do with piston compression , they work on crankcase pressure !
Aug 06, 2014 | WSM 1996-1997 Yamaha Wave Venture 1100 Cc...
I have 2000 Yamaha 1200 gpr ultra wave runner motor turns getting spark will not start any suggestions
Check if there is fuel in the tank and the fuel valve is turned on. Then check the fuel lines. Check and replace the fuel filter. Make sure that the plugs are not fouled and do a compression check on the engine. You need to do the compression check to make sure the crank seal(s) are good. Loose the crank seal and you loose compression.
Sep 19, 2013 | Sport & Outdoor - Others
Yamaha Wave Raider 1994 wont rev past 2900 rpms
check all cylinders sparking ,working by carefully removing plug caps one at a time to see if you can hear a change in sound and check compressions 100psi or more on all !!
Jun 09, 2013 | WSM 1994-1997 Yamaha Wave Raider 700 Cc...
Bose wave radio/CD three CD changer component is playing for about 4 minutes then saying "disc error" and stopping. My primary unit is working fine.
Obviously the laser reader in the unit is picking up interference from dirt or misalignment. You may have to open it up to get to the aser parts to clean them.
Jan 21, 2013 | Bose Wave music system Multi-CD Changer...
Want to play avi movies from archos 5 on my samsung s8500 wave but no sound is available
sounds like a possible incompatibilty issue (wrong codec)
you may have to re-encode your avi, ensuring the audio is compressed in mp3 format
Feb 23, 2011 | Cell Phones
My samsung wave doesnt support all jpeg formats, i put photos on there taken on the same night, with the same camrea, but on some of them it doesnt open it says "format not supported". how can i fix this?...
you should resize the pictures. May be they are too large to be viewed OR too heavy by size, try to compress it.. it will definitely work.
Plz leave a gud feedback.
Oct 21, 2010 | Samsung Wave S8500 Smartphone
Which Mazda diesel engine do I have? RF, RF-CX or RF-N
The engine is a RF- CX the CX denotes comprex pressure wave supercgarger
Jun 14, 2009 | 1988 Mazda 626 Turbo
My honda wave 100 scooter produces white smokes especially when it runs for at least 5 kilometers
your honda wave is air cooled, it could be one of two things, valve seal or piston rings.
Jun 05, 2009 | 2005 Honda NF 100 Wave
Logitech Cordless Wave Keyboard key problems
try a different keyboard to verify problem isn't in keyboard.
Sounds like it could be a driver issue though. check in control panel to make sure it is set as standard keyboard. Also check if there was any software that was installed with this keyboard, it could override windows configuration.
Aug 08, 2017 | Logitech Cordless Wave Keyboard
24 people viewed this question
 Grubhead
Grubhead
