Question about First Alert Home Security
My wires got cut smoke video camera what is coming out is yellow wire red wire white wire and then a wire that has no show what are they
It is a First Alert video camera
  • 8 Answers
SOURCE: Wiring issue with the Honeywell HE360A Humidifier
Maybe I can help. this is 24v so it doestn't matter which wire goes where so here goes. 2 wires from humidistat go to furnace, split one of the wires(not both) so they reach the yellow wires on the humidifier. with marettsconnect one of the split wires to one of the yellow wires. do the same to the other split wire and yellow wire. what you should get is one wire from humidistat to furnace then one wire from humidifier to humidistat and one from humidifier to furnace. hope this helps
Posted on Feb 04, 2009
  • 17 Answers
SOURCE: o2 sensor wiring diagram
A new 02 sensor will come with new wires and connector. If not get back with me I think there is a repair kit for that problem.
Posted on Jun 01, 2009
szanti
  • 36 Answers
SOURCE: Security Camera
it is important to know model and make or camera if you want a solution
Posted on Nov 29, 2009
al_kupchella
  • 843 Answers
SOURCE: The 3-way dimmer switch has 4 wires; 1-red,
Incoming white - outgoing white This is the neutral, which just passes through without connecting to the switch
incoming black - switch black the hot wire provides power to the switch
switch red - outgoing red a traveler, will have power when toggle is one position
switch yellow - outgoing black
the other traveler, will have power when toggle is in the other position
incoming bare - switch green - outgoing bare the switch is grounded and it passes through
If this was helpful, please vote.
Posted on Mar 23, 2010
  • 9 Answers
SOURCE: micromark wiring diagram
hi have the same issue found it to be red power black negative yellow video white audio and bare wire is the shared ground for the yellow and white hope this helps
Posted on Jun 05, 2010
I have a security camera and the yellow,white,red and ground have been cut what do I connect here
We'll this is color coding for the video and audio channels assuming you have a separate wire for power.yellow is video ...red/ white for sound.
Apr 11, 2015 | Home Security
How do i wire up camera after somebody cut off plugs
INDUSTRY STANDARD WIRE CODE COLORS FOR CAMMERAS ARE AS FOLLOWS
RED- POWER SUPPLY POSITIVE
BLACK - POWER SUPPLY NEGATIVE
WHITE- VIDEO CENTER
YELLOW- AUDIO CENTER
THE SHIELDS ON VIDEO AND AUDIO HAVE TO BE JUMPERED TO BLACK - POWER SUPPLY NEGATIVE
NEVER ALLOW POWER SUPPLY POSITIVE TO TOUCH VIDEO OR AUDIO LEADS
Oct 09, 2014 | Lorex Home Security
5 wire security camera wiring diagram
standard cctv camera wiring
red for + 12v
black for comm
yellow for + v (+video signal)
white for -v (-video)
Jul 09, 2014 | Lorex Corp SG6184S Weatherproof Mini Color...
I trying to connect my SFC-4160 (security first color ccd camera) the wiring has been cut n there is 5 wires black,red,yellow,white and a bare wire ???? help
Inside the camera is a 4 pin connector connected to the LED Board, with the connector in hand, turn it till you see the pins inside the connector, from left to right wires 1st-white, 2nd-black, 3rd- bare wire or shield, 4th-red, yellow is not connected, the RJ45 end, face the latch away from you, wires are 1st-red, 2nd-white, 3rd-yellow, 4th-shield(bare wire), 5th-black, the LED Board has the wire positioning marked,,,,,
Nov 27, 2012 | Car Audio & Video
Cut wires on bunkhill weatherproof security camera#95914
My bunker hill has a black, white, yellow and green. I am confused with the white. Help
Oct 17, 2012 | Home Security
Micromark wiring diagram
Feb 09, 2010 | Swann Communications DVR4-Pro-Net...
Need wireing map for cv67 i have four wires red black yellow white whats what?
Only red(+) Black(-) and Yellow (Video) is used if you just cut off that mini din plug end and were looking at the wires coming from camera. I bought some standard power and bnc pigtails from DX.com and replaced that mini din cable they use to make their connections to a standard cctv type.
Un-screw the main lens cover and you will see a screw ring and by taking a verner caliper to catch on both sides you can unscrew camera unit ring and when you look inside the only wires you need to solder to new pigtail is red/black/yellow each to their own color.
Pushing the pigtail thru may be a little pain but with a little spit on wire makes it a lot easy.
Re-assemble in reverse and you should be up and running.
Camera runs on 12 volt with center of plug positive and video bnc center is video.
Hope this helps.
Sep 28, 2009 | SVAT CV67 Hi-Res Outdoor Weatherproof...
Home Security Logo
Top First Alert Home Security Experts
charlie rodriguez
charlie rodriguez
Ronny Bennett Sr.
Ronny Bennett Sr.
woodzowl307
Are you a First Alert Home Security Expert? Answer questions, earn points and help others
