My samsung flatscreen picture is starting to look really fuzzie in some areas on the screen it is almost like a picture on top of a picture.
  • Jeff
    Jeff May 11, 2010
    what is the model code?
  • Nathan Wells
    Nathan Wells May 11, 2010
    Is it an LCD or a Plasma?
  • 585 Answers
Fuzz balls in some areas on plasmas can actually be adjusted out on the Y board first mark the controls with a sharpy then watch the fuzz spot as you turn the controls a little to see which one clears up the picture. the back needs to be off and the Y board is laft side when you are facing the back
Posted on Aug 01, 2009
Fuzzy/Scramble screen when first turned on.
check solder joints on top of screen some screens were sub contracted to a chineese company called chi mai and had inherant defects
Nov 30, 2012 | Samsung LNT5265FX 52 in. LCD Television
Colors are separated on flatscreen sanyo
T'Con board to this set should be suspected. Seek expert tech support.
Jun 20, 2012 | Sanyo Televison & Video
Phillips 47" flatscreen sounds still
If the TV menu displays your problem is most likely not the Tv , but is caused by the signal source:
Cable box or connections. Reboot everything test using other sources like a DVD player to isolate the problem.
Aug 20, 2011 | Televison & Video
Samsung flatscreen lcd picture went out 18 months after purchase. I hear sound but see black screen.
i have had to repair a few of those and the best! info i can give you is this!! the main board has to be swapped out! there little that you can do to repair it most of the parts are manufacturer availibility only! and non serviceable! by the user most boards are shipped complete at a cost of $90-$160 depending on supplier and area.
Jan 12, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
New flatscreen Sanyo tv. Picture is to big for the screen
use the picture button to change the shape, Most likely you have it set to picture 3 which would cause that.
Jul 04, 2009 | Sanyo DP32648 32 in. LCD TV
50 inch wide screen with fuzzy picture
If it recovers by itself, yes, it should be a cheap fix. It's most likely bulged/leaky capacitors in the power supply and flyback area. Check all the capacitors, and in my experience if you see a suspicious one it is best to replace all of them in that area, they are cheap and will save you from more serious issues.
Jun 19, 2009 | Toshiba Televison & Video
Fuzzy/blury fonts on a samsung syncmaster 920nm
Good morning! Please review/check the set-up settings of your samsung flatscreen, best to refer it to the operations manual of the monitor which should be included when you bought it. best regards.
May 02, 2009 | Samsung SyncMaster 920NW Monitor
Philips 34pw9818 fuzzy screen
Inside the set you should see a large part with a red wire coming out the top. That is the flyback transformer. There will be 1 or 2 controls on the back of it. One should be labeled screen and one focus. Carefully adjust the focus one until the picture is again in focus. Please note that in that area are high voltages (33,000V) that can be dangerous. Be careful where you touch. IT is best to have a mirror so you can see the picture while adjusting the focus control.
Dan
Feb 04, 2009 | Philips 34PW9818 34" TV
Kogi Monitor with fuzzy text
Here is one small solution. goto start: -> control panel -> display click on the "appearance" tab. then click on "effects" check the box that says: Use the following method to smooth the edges of screen fonts (and make sure to choose "cleartype") You should notice the fonts are a little sharper as well as having a backdrop.
Mar 23, 2007 | Kogi L9CH 19" Flat Panel LCD Monitor
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
