Question about Refrigerators
Removing rear freezer panel model et20dk
Can not get unscrewed panel past brackets that hold the shelves
MicrowaveSvc
  • 9098 Answers
SOURCE: remove kenmore microwave model 7218815180, 1988 model
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
For some models, manuals are available free if a button shows up to the right of the parts listing.
Otherwise, you will need to order an installation / owner's manual from the parts list.
If it doesn't show up, you can contact support via phone numbers available through that page's links.
Posted on Sep 28, 2008
lenwest
  • 150 Answers
SOURCE: Removed bottom freezer drawer while moving & can't get back in
Try picking up the drawer and tilt it up as your putting it in,push it far enough and the wheels or what have you will drop in.Or try the opposite.
Len
Posted on Feb 19, 2009
SOURCE: maytag upright freezer model MQU1556AEW
I experienced the same problem last week with my freezer. Apparently the change in temperature during defrosting allows the blade locking mechanism to slide on the motor shaft during the spinning operation. The blade pulls itself along the shaft until it comes in contact with the motor mounting bolt. If your freezer just stops getting super cold, but remains cool and you don't hear the fan spinning, remove the inside back panel and check the fan blades for freedom of movement. I almost disposed of the freezer this past week but decided to make one last check of the mechanisms.
Posted on Apr 07, 2009
  • 56 Answers
SOURCE: Need two door shelves, Sub Zero, 251 RFD, the last two shelves
http://www.subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code will get you to the nearest SZ?wolf parts distributor.
Posted on Apr 23, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: how do you get to the file valve? Do I remove the rear panel?
You get at the the valve by removing the washing machine cabinet, not by taking off the back. The process is described well in pictures here. It's not a difficult process at all, and you can save quite a bit by doing this repair yourself.
Posted on May 08, 2009
GE side by side refrigerator model GSS22JEPD freezer ices up.
remove the freezer shelves and remove rear inside panel in freezer,under the evaporator located here theres a heating element,it has probably opened up and can no longer heat,this is a very common problem with g.e. SxS refrigerators,replace it by unplugging unit,then remove 2 screws holding heater bracket and unplug heater and replace g.e.heater part # is WR51X10101
Jun 16, 2012 | GE Refrigerators
Fridge and freezer are set at 7 and the fridge is cool but not cold and the freezer has not been able to freeze a box of freezepops that have been in (2) days, The back wall of the freezer has frost...
http://www.partselect.com/PS303781-GE-WR51X10055-Defrost-Heater-Bracket-Assembly.htm?SourceCode=1&ModelNum=HSM25GFRASA
WR51X10055 is the part number of the defrost heater and bracket assembly. Item #230 in the diagram. On this unit it is a plug in unit.
It is relatively easy to replace. Remove food from the freezer section, remove shelves, remove back panel. Unplug refrigerator. Defrost the unit by either leaving the door open to the freezer section or you can hurry it up with a hair dryer. After it is defrosted, plug in the new defrost unit, plug the frigerator back in and reattach the back panel, shelves and food.
Jun 10, 2011 | Hotpoint HSM25GFRSA
The freezer is working but the frig. is hot, when is the freezer fan supposed to come on ? How do I test it - I have a multi meter but do not know when it is supposed to be getting power.
How To Test the Evaporator Fan The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer.
Caution: Before testing the fan, unplug the refrigerator to avoid an electrical shock hazard.
The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver.
evapfan.jpg Remove any screws that secure the fan or fan housing so that you can access the fan's wiring. Typically two screws secure the mounting bracket in place (labeled "A" below). It may be easier to remove the entire rear panel if the mounting brackets screws are inaccessible.
Spin the fan blade, it should move smoothly and freely. If the movement is not smooth, the motor should be replaced.
Test the fan for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading of zero ohms. If the fan does not pass this test, it should be replaced
Jun 08, 2011 | Haier Refrigerators
Whirlpool model gb22dkxgw00 bottom freezer working ok but refrigerator is warm i think the fan is not working but how do you get to it?
Good day,
You access the fan motor after removing the rear panel in the freezer compartment.
Changing the motor is pretty much a nuts and bolts job, but like all bottom freezer models it's somewhat akward to remove the shelves ect. to get to the panel.
Time and patience is your friend here.
Aug 18, 2010 | Whirlpool Refrigerators
Refridgerator is only cold on the bottom. Fridge is a side by side and both sides are doing the same thing. Top shelves are not cold or freezing, but the bottom ones are. What is causing this?
Good day,
The common reason for this is the fan motor behind the rear panel in the freezer compartment is not running.
With the machine on and running, open the freezer door. You should hear the fan running.
If not the motor can be accessed by removing the rear panel in the freezer compartment.
Replacement is a nuts and bolts operation.
Dec 17, 2009 | Refrigerators
Marvel, Model 61 RF ww-F made in 7-19-2000
Dear John,
Contact the factory directly at 800-223-3900 8:00am to 5:00 pm EST. I believe the bar pn is 42241938 (for the 2nd and third bar) and the top bar pn is 42241937. (I am going by memory so have them verify it). They also have a kit that has both side hinges and new springs for the freezer door. If you can't get through via phone contact Tim Malloy using tmalloy@northlandnka.com. He's a little overloaded but should get back to you within a day or two.
Nov 01, 2009 | Marvel 61RFxx 24-inch Refrigerator/Freezer
Evaporator fan noise. How do I access the evaporator fan motor to replace it?
Turn off the refrigerator. Remove the freezer shelving and bins. Remove the screws holding the rear panel inside the freezer. Repair or replace the fan motor.
You may also have to remove bin supports from the side wall to get the panel out depending upon your model. The model number posted is incomplete.
Sep 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag upright freezer model MQU1556AEW
Sep 22, 2008 | Freezers
Bracket for tv
use shelve brackets, I did and they worked fine
Jan 18, 2008 | Akai LCT2715 27 in. LCD Television
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
