Question about Cameras
How to release dial lock? - Cameras
I have a brand new Travel Pro suitcase. I want to set the combination lock. How?
Some Travelpro bags come with an external lock upon purchase included in the user information package with the user manual and the add-a-bag strap or hook. This external lock can be looped through the zipper openings to secure your bag. To set the lock to your combination, follow these steps.
  1. External Travelpro Lock:
  2. Unlock the mechanism by pulling up on the metal lock rod. The 3 dial combination must be set to (0-0-0) factory combination if new, or the existing combination if used to unlock.
  3. Once released, rotate the lock rod to align with the notch of the dials, usually perpendicular to the long side, or about 90 degrees from its lock position.
  4. Select a new 3 digit combination.
  5. Press down the lock rod all the way and hold in that position while you turn the dials to reflect your new combination. NOTE**The lock rod must be held down all the way until you have your 3 digit combination in place, otherwise an unknown combination will be set while you adjust the dials.**
  6. Once your new combination is in place, release the lock rod. This sets the new combination.
  7. Return the lock rod back to the locking position and double check that your new combination does lock and unlock.
  8. Scramble the dials in order to keep your luggage safe and secure.
Jul 01, 2017 | Luggage & Travel
Where is the power button for canon eos elan iie?
There isn't one. To turn on the camera, hold down the lock release button (just inboard of the command dial) and turn the command dial from the "L" position. To turn off the camera, hold down the lock release and turn the dial to the "L" position.
If you need a manual you may download a copy from here.
Oct 31, 2012 | Canon Photography
I am on vacation, so no book. I have a nikon d7000 and i want to set a timer to take pictures of my hubby and i. Can u help me?
Press the release mode dial lock and turn the release mode to the one-handed clock symbol. Press the shutter release button to start the self-timer.
If you want to change the length of the self-timer delay, it's the Custom Setting #c3.
The release mode dial is on the top left of the camera (as viewed from the back). The lock is just below and left of the dial.
You can view/download the manual at
http://support.nikonusa.com/app/answers/detail/a_id/17008
Sep 09, 2011 | Nikon D7000 Digital Camera
How do I reset a 4 dial Samsonite combination lock
Hello sstacy1,
You can follow the steps below to fix your problem on how to reset your 4 dial Samsonite combination lock:
  1. Set the dials to 0-0-0. Find the lever or button next to the dials.
  2. 2If your lock has a lever, lower it and turn the dials to the desired numbers. Return the lever to its starting position.
  3. 3For locks with a button, push the button towards the dials and turn them to the desired numbers. Release the button.
  4. 4The lock is now set to the new combination.
Read more: How to Reset Samsonite Luggage Combination Locks ' eHow.comhttp://www.ehow.com/how_4761466_reset-samsonite-luggage-combination-locks.html#ixzz157Q4Ap
Hopefully it helps.
Thank you for using fixya
Sep 08, 2011 | Health & Beauty
How to set up Nikon ML-L3 on D700
You don't need to do anything on the ML-L3. You need to set the release mode on the D700 to the remote mode. Press the release mode dial lock release and turn the release mode dial (pages 27, 77, and 80 in my copy of the manual). If you need a manual, you can download one at
http://support.nikonusa.com/app/answers/detail/a_id/15979
Aug 15, 2011 | Nikon Cameras
I want to set a combination for the lock
Jan 09, 2011 | Samsonite Silhouette 11 Hardside Spinner
HOW TO CHANGE LOCK COMBINATION IN A SAMSONITE LUGGAGE OYSTER GL
I forgot my locker combination and my luggage is locked.How can I open it??
Nov 13, 2010 | Samsonite Silhouette 11 Hardside Spinner
I need to know how to set the self timer for a nikon d7000
Press the release mode dial lock release and rotate the release mode dial to the self-timer (one-handed clock) mode. See page 80 of the manual.
Oct 30, 2010 | Nikon D7000 Digital Camera
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Cameras Logo
26 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
