Question about LG Televison & Video
LG 47LN5750-uh. While watching TV the picture went blue and has no sound. Plugged in other devices into usb and other HDMI slots, still blue screen no sound. suggestions? Main board or T-con?
    Sergeant:
  • LG Expert
  • 330 Answers
Main Board. If changed main board, the problem still there, please try a new T-CON board.
Posted on Apr 26, 2017
Testimonial: "Changed main board. Still same problem, blue screen, backlights on but no picture. Any other ideas?"
How do I fix LG 47LN5750 TV with NO picture but HAS sound?
This is a LED TV so there won't be an inverter board, they're only on LCD sets, what is wrong with your set is you have shorted LED lamps in the panel, its a common issue with this model TV, Ive replaced dozens of them in the last couple yrs, its not a fun job to do as the panel can be damaged very easily if extreme care isn't taken when handling it, watch some youtube vids to get an idea of how to do it...Good luck!!
Apr 04, 2018 | LG Televison & Video
Is the power supply board on my TV the cause of no back lights?
Hi Grant,
This is a backlight issue. Defective LEDs in the backlight array need to be replaced. Welcome further assistance.
Good Luck
Feb 13, 2018 | LG Televison & Video
LG 47LN5750-uh. replaced the main board. picture still blue, back lights are on but not picture. besides throw the tv in the ditch, what should I check next?
Either you have a bad panel or the T-con board is not processing the video to the screen. This is the board between the main board and the screen. There is one on E-bay for just under $35.00. Hope this Helps.:)
Apr 28, 2017 | LG Televison & Video
LED tv LG 50LN5200 with no picture but has sound
Faulty the backlight
It is necessary to remove the panel and replace defective LEDs
Best Regards!
Oct 31, 2016 | LG 50 Inch LED TV 50LN5200 LN5200 Series...
My lg plasma TV saysvno si GB nalv has volum but no picture
Hi Kelly, The link below is a YouTube video showing how to fix a Samsung television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
https://www.youtube.com/watch?v=Bf5T2wwtydY
LG No Picture Screen Flash 47LN5200 47LN5400 47LA6200 47LN5700 47LN5750...
May 01, 2016 | LG Televison & Video
Lg model 47ln5750 screen went black
That model is an LED Backlit unit. The LED driver could be bad or there could be a power supply problem. Sometimes the problem is a cable connection. Is there an picture that you can see in a dark room? If you can see a faint picture, the problem is probably the LED back light.
May 18, 2015 | LG 47LN5700 47" LED TV 1920x1080, 120 Hz,...
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
Televison & Video Logo
54 people viewed this question
