Question about Gestetner Office Equipment & Supplies
How to fix replace new toner error problem on Gestetner dsm620?
checkitright
  • 1362 Answers
SOURCE: gestetner 3245 (used toner case nearly full)
most likely it will be on the right rear. look for a door w/ a couple of screws, there is a white plastic container, empty or replace and put back. should clear on it own when done.
Posted on Sep 26, 2008
  • 37 Answers
SOURCE: Gestetner DCS424 error message: replace used toner bottle
There are 2 waste toner cartridges, be sure to empty these 2 cartridges . If you remove the waste toner in both cartridge it will automatically clear the error message.
Posted on Mar 01, 2009
goodgold
  • 389 Answers
SOURCE: HOW DO YOU FIX TONER BOTTLE WHEN ITS FULL ON
West toner is situated in user manual.Thanks
Posted on Jun 07, 2010
  • 2072 Answers
SOURCE: I have a Gestetner DSm651sp
Most likely the toner dispenser is blocked. Its not getting the ink into the system. Did you shake the bottle well to be sure its not packed inside the bottle?
Posted on Jun 04, 2011
anyprinters
SOURCE: my gestetner DSM735 keeps saying add toner.
A little cape fixed on the toner Bottle,When you change the Bottle,the cape left in side the toner hoper,You have to tack care of this
Posted on Apr 08, 2014
MP2000 not loading toner
please check if the toner is not lumpy cos this can also cause that.
or also check the buttom of the toner bottle since the moto and the bottle may not have the same format .
May 22, 2014 | Ricoh Gestetner DSM615/ DSM616/ DSM618/...
Horizontal line on dsm 620 printers
check the drum or scanner glass both the ADF and platen or can be the fusing unit hot roller problem
Dec 29, 2013 | Gestetner DSm620 All-In-One Laser Printer
Error code sc322 gestetner
It's an error code for a laser synchronization error. Possible causes according to the service manual:
•Laser synchronization board connectors loose, disconnected, or
damaged
•Laser synchronization board defective
•LD drive board defective
I've also seen where toner leaks and covers the laser sync board and causes this error. Try cleaning any toner off the Sync board and see if that fixes it.
Oct 11, 2012 | Gestetner DSm745 Black and White Copier
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Wat does it mean if the machine is saying toner cartridges not set properly
the main reason for this could be when you replaced the toner cartridge you have either not put in correctly or an incorrect toner put in. Check the other cartridges to see if when you remove one you get the same error if this is the case you could have a faulty toner. Is the toner an origina Gestetner toner you may need to return it...K
Jun 03, 2011 | Gestetner DSc224 Copier
My gestetner DSM735 keeps saying add toner. replaced toner and developer still saying add toner
The first thing i can tell you is that is weird!!!!
Because if you change the developer that error should disappear. It could appear later but not in the moment because the developer already have toner and the TD sensor will read it.
And that's the question: When you said "replace developer" you mean just the developer or the DEVELOPER UNIT??? Is your TD sensor working good????
Feb 23, 2011 | Gestetner DSm735 Black and White Copier
Feb 27, 2009 | Gestetner Copier
DCS424 error message replace used toner bottle
Ricoh 1018d won't add toner after installing toner bottle.
the part numbers are different for each toner from ricoh, Lanier, Savin and Gestetner. From what I recall is the bottles are different, check the old bottle vs new. Also if the machine had run very low you may have to open and close the fron cover several times, this intiates a toner feed program.
www.p4photel.com
http://www.websitetoolbox.com/tool/mb/copierquestions
Feb 26, 2008 | Ricoh Aficio 1018D All-In-One Laser...
Gestetner dsc38 error code
You have an improper black toner density. Likely your black toner suction mechanism is clogged or the black toner supply clutch is not working.
Feb 21, 2008 | DSC GESTETNER - DSc38u Color Printer
95 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
