Question about LG Ovens
LG gas oven digital display F0 controls do not work MOD LRG30357ST pushing buttons nothing responds.. I took of the ribbon cables and all connections and still inop..
Powerman
  • 68 Answers
SOURCE: GE Profile JGB97 Self Cleaning Oven Controls won't work
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following:
hutchipop@yahoo.com
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
Posted on Feb 07, 2008
  • 109 Answers
SOURCE: Gas stove works, but oven does not
yes replace the ignitor, this is the most common failures of ovens not coming on.
Posted on Mar 30, 2008
  • 3 Answers
SOURCE: lg lre30451sw oven the start button doesn't work
This happened to me on Christmas Day morning & it happened once before. I finally remembered how I fixed it. Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start" Then click on "Bake" set your temperature & push "Start". Hope this works for you. It got me out of cooking Christmas Dinner, but I fixed it today!!
Posted on Dec 28, 2008
  • 111 Answers
SOURCE: GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Posted on Jun 20, 2009
award462
  • 395 Answers
SOURCE: chef gas oven user manuals
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
Posted on Jun 03, 2010
The keypad is non-responsive and a FO code is displayed in the upper over display area. There is also a periodic beep.
Hi
Error code F0 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 05, 2011 | Kenmore 41389 Electric Double Oven
KENMORE OVEN HAS FO ON KEYPAD.ANYTHING I CAN DO BEFORE REPLACING KEYPA..MAYBE RELAY SWITCH
Hello,F0,displaying on your keypad means "stuck keypad" and these mean the relay is turned on and to determine if the problem is with the Key Panel or Control,follow these steps
1. Pushing Clear/Off pad
2. Disconnecting Ribbon Cable from control and wait at least 30 minutes to see if the code reoccurs.
If the code reoccurs, the problem is in the control, that means you have to replace the control.
If the code does not reoccur, the problem is with the Key Panel
Thanks
Jun 03, 2010 | Kenmore 42161 / 42169 Electric Single Oven
Error Codes F0 and F7 on G.E. Wall Oven
F0 , F1 , F7 - Stuck keypad may mean relay is turned on.
You could have a Tech Sheet from :-
http://www.repairclinic.com/0078.asp
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 02, 2010 | GE Ovens
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
Jun 20, 2009 | GE JKS05 Electric Single Oven
GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
F0 error code on GE Profile PT956 double electric oven
you can also put a piece of paper between the ribbon cable where it joins up before the connector. It has been reported that the cable will short in this area. Try that before spending more money since most of the F-codes appear to be cable related.
Dec 01, 2008 | GE Profile PT956 Electric Double Oven
F0 error code on GE wall oven
I had the same FO error. It turned out that the ribbon cable from the front panel was not making good contact where it mated with the circuit board. Remove ribbon cable and clean contacts on ribbon cable. Replace cable and problem should resolve.
Oct 13, 2008 | Ovens
Double Oven says "F0" and beeps continuously
The fault code "F0" is indicating a possible stuck or shorted key pad or oven control board failure.
Determine if the problem is with the key panel or the oven control board by:
1. Pushing Clear/Off pad.
2. Disconnecting the Ribbon Cable Connector from the control board and waiting at least 32 seconds to see if the Code recurs.
If the code recurs, problem is in the control. Replace control.
If the code does not recur the problem is the Key panel and it would need replaced.
This test is normally done by an experienced service technician to avoid any possibility of getting shocked. This has to be done with voltage applied to the wall oven. Extreme caution should be exercised while testing.
I recommend calling a service technician to diagnose and repair your oven.
Jun 13, 2008 | Kenmore 47732 / 47734 / 47739 Electric...
F0 error - My GE Over displays an F0 error & constantly beeps
Appu, the F0 error for this built in means there is a shorted or stuck off key. Sometimes this can be resolved by removing the keypad ribbon cable from the board and cleaning the ends with an eraser. If that doesn't work, you want to find out whether its the board or keypad by ohming the ribbon cable, 3 to 4, probes on the conductor side...should read 125 to 1750 ohms while pressing the off key. Catriver..post back.
Apr 29, 2007 | GE Profile JK915 Electric Single Oven
Ovens Logo
Top LG Ovens Experts
Coss
Mike Carew
Are you a LG Oven Expert? Answer questions, earn points and help others
