Question about Dell Computers & Internet
I have problem with communination of x dream bike the message is NOT CONNECTED I have checked the drivers and pl-2303 Chip,its ok The dell PC understands the connection.
  • 13433 Answers
SOURCE: Dell Optiplex GX520 message:
there is a 3 volt flat battery inside the computer, it in most cases clearly visible.
Replace it with the same type of battery, then adjust the clock in the system setup.
All done, all fine.
Let me know if you need anything else.
Posted on Feb 17, 2009
SOURCE: connecting and recording sony hdtv, rdr-hx780 recorder,sony dream system
I have the same system, except for the TV, I have a project (that part doesn't matter).
From your Sat. go straight to your AV receiver
Again from you Sat. (all of the AV outputs are all live), go out from either 1 or 2 and go to your recorder Line 1 in.
From you AV receiver go to your TV.
All you have to do is hit record and you will record whichever channel you are on. I am having difficulty getting it set up as a PVR, but will figure it out sooner or later.
Hope this helped.
Posted on Feb 24, 2009
  • 32281 Answers
SOURCE: i cant find vista drivers for dell optiplex gx270 pc
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop. This will open the page where the specific drivers for your model laptop are located. Also make sure you select the Windows XP or Vista version of the driver for your Windows operating system.
Click on this link :-
Posted on May 02, 2009
  • 35 Answers
SOURCE: gmail not syncing in HTC Dream
  • Go to 'Setting', choose 'Data Synchronization', choose 'Data Synchronization' again, then make sure that the 'Background Data', 'Auto-sync', & 'Gmail' boxes are checked.
  • Go to 'Gmail', press the 'Menu' button on the front of the phone, select 'Settings', choose 'Labels', make sure 'Number of days to sync' is reasonable (i.e. 4 days, or 7 days, something that makes sense).
  • Back in the Gmail inbox, press the 'Menu' button on the front of the phone, choose 'Refresh'.
  • You should get your mail. Double check with the desktop version of Gmail.
Posted on Aug 04, 2009
Need drivers for PCI-E expresscard 1/0 adapter
Go to and search for DL-0254103 from "Drivers Search". Or you can use an alternate site: Use this path: Download >> USB to Port Controllers I/O >> PL-2303 Software and Drivers.
Jun 22, 2012 | Port Designs Best Connectivity RS-232...
Can't install OS, Passed full PC Check
OK after doing that DOD, you MUST repartition, and reformat before you can do anything further.
Apr 01, 2010 | Dell OptiPlex GX150 PC Desktop
My igolf neo won't work with Windows 7 if i try
I fixed this problem by going to Start>Control Panel and uninstalling the Java 64-bit program. It is incompatible with the Neo sync application. The other Java program on there is compatible. It worked immediately without even restarting. (I tried the above Best Solution, but on the newer computers, I get a message saying the Vista driver is only for Vista, not for Windows 7).
Jan 30, 2010 | NEO iGolf neo MP3 Player
I want VGA driver for sahara image book 12ws
please go to at first lookup the graphics chip located in motherboard
Sep 18, 2009 | Dell Dimension 8300 PC Desktop
Laptop dell inspiron 1525 sound only when headphones connected
If you can here sound in headphones, but not through the speakers, most likely the phone jack switch is bad. The whole jack needs replacement.
Also, in some cases, it could be more then that, like Audio CODEC chip on motherboard is bad, but lets assume the best.
Apr 19, 2009 | Dell Inspiron 1525 Notebook
Monitor fault
Try removing the RAM from the motherboard & fix it again...... if this will help you u might not need to go service center.......or check the dispaly cable which is connected to your CPU........hope thjis will help u...............Sameerrayan
Jan 12, 2009 | Computers & Internet
Need drivers for nikkai usb to serial converter rs232
I purchased the Nikkai USB to RS232 adapter from Maplin and could not get the device working. (Maplin staff not much help!) The lead uses the Prolific PL-2303 device but Prolific do not supply the drivers to end users.
However I found the drivers that appear to work at:
This then recognises the lead as a COM port. So far everything seems to work OK.
(Null modem check and basic 9600 data transfer.)
I hope that helps everybody.
Dec 08, 2008 | Computers & Internet
LG CU400 camera download
open up the images folder or camera album your pics will be in there
May 10, 2008 | LG CU400 Cellular Phone
Computers & Internet Logo
Alun Cox
