Question about Briggs Garden
My macalister Briggs and Stratton 500series is driving slow on rabbit symbols would this be the cable stretched ?
    Loyalty:
    Visited the website for 30 consecutive days.
  • Briggs Master
  • 861 Answers
Try some sea foam in the gas and let it run for awhile hope this helps
Posted on Dec 24, 2017
5 Suggested Answers
heres2maine
  • 84 Answers
SOURCE: My flymo briggs & stratton quick silver 46d
Your carb needs to be taken apart and cleaned
Posted on Jul 10, 2010
  • 111 Answers
SOURCE: my briggs and stratton 158cc
There is a tab on either side of the carburetor right where the primer bulb sits. You can depress both of these tabs with a screwdriver and pry out the plastic ring that holds the primer bulb in place. You can purchase a new primer bulb (with a new plastic tab) from a local mower shop or from a small engine repair shop. When you install the new primer bulb, put the rubber bulb in first then put the plastic ring on top and press it in until the tabs click on each side. It should work correctly after the tabs are clicked properly. You can take off the air filter and look into the carburetor to see if the unit is priming correctly. I hope this helps you out.
Posted on May 10, 2011
SOURCE: briggs and stratton how to adjust drive cable
it should have a throttle adjuster at top of cable
Posted on Jul 06, 2012
capitootio
  • 13 Answers
SOURCE: 23 HP Briggs and Stratton engine turns over very slow
low battery or starter is binding
Posted on Jun 21, 2015
Briggs & Stratton 35 Classic. How to fit the cable to drive the tines. Help!
briggs and stratton 35 classic is the model of engine not the rotavator
May 06, 2015 | Briggs & Stratton Garden
Briggs & Stratton 35 Classic rotorvator. How to fit drive cable to drive the tines. Help!
on tillers the control cable lengths need to be kept the same as they use the free end cable lengths to denote how much pressure is put to clutch pressure idler wheel , too long not enough pressure, too short too much pressure
Briggs & stratton 22" brute front wheel drive cable has came loose and i dont know where its suppose to attatch
most of the front drives have a pulley . beside the pulley is a plastic arm your cable will connect to it .. like i said most models .
Nov 04, 2013 | Briggs & Stratton Garden
Drive belt slipping
You maybe able to adjust the cable. the belts stretch when the get old. if that don't work you may need a belt.
Oct 26, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
500series Briggs& Stratton won't start when warm
check valve clearance when hot and adjust as this is a common fault with B&S
Aug 06, 2013 | Measuring Tools & Sensors
Castelgarden 18hp
the engine or the gearbox/transmission drive slows down???
May 25, 2013 | Briggs & Stratton Briggs Stratton...
How does choke work on 20 horse briggs the throttle only has turtlespeed and rabbit no place marked choke
Many have auto chokes, which are set to close and open essentially with spring pressure. You can verify this by looking into the intake, ahead of the throttle plates. Other designs use a priming bulb to accomplish the same function.
Nov 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
The mower deck belt on my scotts s2046 comes off after a minute or so of operation. What's going on? Thanks
you should have some type of belt tensioner,most common type is a pulley with a spring to hold pressure on belt.Spring may be missing or stretched {2}belt could be stretched {3}pulleys may be out of alignment
Oct 05, 2010 | Briggs & Stratton Starter Scott's Equip...
Motor runs wide open when set @ slow speed
It could be that the governor spring has become disconnected or has broken on an end where it hooks onto the throttle linkage. If the spring is OK & throttle linkage is not binding it could mean the governor drive inside the engine has failed preventing the governor from operating correctly. You may need to take the engine to a mechanic to fix the problem.
Sep 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine working ok tractor slows down to crawl after sort time of use
Check to ensure governor spring is not stretched or possibly missing. Here is a link to their web site so you can check location of parts and also get info on your unit in depth. Hope this helps.
http://www.briggsandstratton.com/maint_repair/
May 22, 2009 | Briggs & Stratton Garden
Garden Logo
27 people viewed this question
Top Briggs Garden Experts
Mike
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
