Question about Craftsman Garden
My craftsman 6.75 push mower will run for a few mins then die. I never changed the oil until today. Actually no oil left in chamber so added a qt. starts but will run fully if tilt handle to ground
    Problem Solver:
  • 20 Answers
Posted on Apr 26, 2017
My lawn tractor craftsman 14.5hp IC OHV B&S stalls approx. 5 mins after starting so I restart and it can stall in another 10-15 min again and so on.
you may have some debris in your gas tank blocking the pickup tube. It will float away when the mower dies, then block the tube after it runs again.
Jan 03, 2017 | Craftsman Garden
Run for 15 min then dies. It was low on oil. Added oil over the full line now it runs for 3 min running rough and then dies To much oil now?
Your mower dying would have no correlation with how much oil you have in the engine. Didn't I answer this question for you yesterday?
Your problem is fuel related. Fuel goes off, so it should be fresh from the gas station every season. Check lines for kinks. Check lines for air locks. Check your fuel filter if you have one. Check that the fuel tap works properly.
Apr 03, 2016 | Garden
Have a 6hp craftsman mower starts and runs for 30 sec dies have replacer carb with running mower carb replaced plug replaced coil flywheel key fuel tank sounds like it is seizing up slows down for a
you have bad valves seats probably broken loose do to overheating replace short block or by new motor short block cost to much 300.00 new motor 225.00 to 245.00
Sep 07, 2014 | Garden
Mower dies after 5 min. of mowing
check for spark when the engine dies you might have a bad coil
Aug 15, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
What does the hour meter on my mower actually tell me? It is flashing between hours of usage and chg oil. I changed oil and filter about four running hours ago. I cut grass for a few hours and then...
Hi, the meter flashes oil change when they are due(at pre-programed intervals) and will stop flashing two running hours after flashing starts. The hours that are showing are total running hours from new. Hope this helps, regards Phil.
May 31, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Won't stay running
you may need to disassamble the carb and clean it thoroughly.
May 09, 2010 | Poulan "Poulan" Push Mower
Toro 6.5 hp pushmower shuts off after ~ 5 mins of
It may have a gravity float residing in the carberator which may be cracked and will show same symptoms.If not garvity float, check for loose connection, heat and vibration my cause it to die, it cools and then restarts.
Aug 02, 2009 | Garden
Craftsman riding mower starts, then runs for 30 seconds, then pours out white tons of white smoke and sputters and dies. It will then re-start and repeat the same. The amount of smoke is tremendous. It...
The smoke is oil going in to the combustion chamber, will have to check for broken rings or piston. also if the tractor was stored in a position that the oil would run to the combustion chamber it will do that untill all the oil is burn
Mar 22, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
29 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
