Question about Cycling
I have this Next PX 6.0 men's bike. The wheels are disassembled from the frame. I can only order parts online. Can someone help me identify what size bolts and screws I will need?
  • Cycling Master
  • 1,034 Answers
There's no way to tell what you need from that photo, and putting a bike together is more than having the right parts. They have to be put on and adjusted properly. Look in Craigslist for people who fix bikes if you have no local shop, or find someone who is a bike enthusiast to help you. If you have a Walmart nearby check with them, as they used to sell them.
Posted on Apr 24, 2017
    Master:
  • 923 Answers
2 Suggested Answers
  • 1034 Answers
SOURCE: I have Next PX 6.0 Mountain Bike that has a missing connector bolt/nut that is located above paddle/crankshaft and connects front with back of this bike.I need to know the name and size of this part?
I don't know the name of the part, and it's going to be very difficult to ID the part over the Internet. That is a bike that sells for under $100, and therefore unusual OEM parts would be very hard to find. Take to a bike shop to see if they can suggest a fix.
NOTE: The bikes are distributed by Dynacraft, which has been the subject of suits and settlements due to serious fork and frame problems. Dynacraft BSC Inc
Posted on Dec 07, 2016
Trying to identify a bicycle to buy replacement parts FH20083 can you help
Unless it's the frame, most parts are supplied by others, eg. Shimano gear shifters. Check with online or local cycle stores to find what you need.
May 04, 2017 | Cycling
Dec 07, 2016 | Mountain Cycling
Need to find a new seat/replacement post for 24" Next PX 4.0 Boys Mountain Bike, Black
I am a privet bike repair shop the seat post is a 25.4 mm 9 inch log i have a used seat post in stock and a new seat in stock that will work with a next px 4.0 a had the same issue you contact me on my web site
May 08, 2015 | Next 24" PX 4.0 Boys Mountain Bike, Black
YES SOMEONE STOLE THE SEAT AND POLE TO MY MOONGOOSE SPIRE BIKE AND I NEED TO KNOW WHERE I CAN BUY ANOTHER ONE
measure the diameter of the hole in the frame where the seat post goes. Get online and order one. They vary in size so get a precise measurement.
Apr 03, 2013 | Mongoose Spire 26 Inch Men's Mountain Bike
NEED REAR FRAME
Try contacting the guys at Oldroads.com. All inclusive bike experts and bikes.
Sep 25, 2012 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Mongoose Maxim 26" mens bike-
If it's "broken" or even bent it will have to be replaced. Your frame or derailleiur hanger may also have taken a fatal hit.
You should consult a Bike Shop.
If you still want to DIY you'll need to obtain some specialized tools and skills.
http://www.parktool.com/blog/repair-help/rear-derailleur-hanger-alignment
http://www.parktool.com/blog/repair-help/chain-installation-derailleur-bikes
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Jul 09, 2011 | Cycling
How do I remove the training wheels?
You will need either an adjustable wrench, a socket of the right size, or a box end wrench of the right size
(If you read through this and still don't feel like you're up for it, your local bike shop will be more than happy to do it - and it will either be really cheap or free)
The bolt you need to loosen is on the back wheel where the training wheel meets the bike. Find the right size tool for the job.
Grab the back wheel and try to wobble it side to side, then remember how much give there is so your end result gives the same feel.
You may need a second wrench to place on the nut/s between the frame and the hub to prevent this from turning, though it will probably only be needed for tightening everything after you're done.
-Start on 1 side (doesn't matter which one) and loosen the outside bolt with your wrench/socket
You will need to remove it completely to take the training wheel off of that side.
-Slide training wheel off and hand-thread the bolt back on, not tight yet.
-Do the same for the other side, both training wheels should be removed at this point.
It may help to have someone else for this next part
-Pull the back wheel as far back as it will go, don't kill yourself, but make sure the chain won't slip off because it's too lose. Make sure the wheel is aligned with the bike frame, not twisted, otherwise it will loosen on its own
-Tighten one bolt on the outside down onto the frame. This is where you might need to use a second wrench to keep the hub from rotating. Don't turn the nuts on the axle in the area inside the frame (between the frame and the wheel) as they should be tightened correctly, instead just hold them steady while you tighten the outside nut onto the frame. If that wasn't clear, you're pinching the frame between the nuts inside, which you never moved, and the nut outside the frame, which you removed to take the training wheel off.
-Repeat for the other side while still maintaining tension on the chain.
-You should be done, check to see if the wheel can wobble side to side and compare to your earlier result. If it moves too much, continue tightening outside bolts (both sides until they're good and tight)
Mar 17, 2011 | Huffy Boys Pro Thunder Bike (20")
In putting together my 26"
Loosen both nuts on front wheel.
Stand bike straight up, or set bike upside down on seat and handlebars.
With fingers on fork and thumb on wheel, pull wheel so it is centered on fork.
Now tighten one nut part way. Keep holding wheel.
You may need somebody to help.
Then tighten other nut.
Go back to fist nut and tighten a bit more.
Repeat back and forth tightening until nuts are tight and wheel is in center of fork.
Dec 25, 2010 | Schwinn Men's 26" Jaguar Cruiser Bike
Men?s Schwinn 700C Prelude Road Bike Assembly
Pedals can be purchased in pairs and some road bikes do not come with pedals. They have 2 different axle sizes 9/16" and 1/2". There are road pedals and road clipless pedals.The ones with clips and quick bindings require special biking shoes that the cleats clip into.Quick releases come in various lengths for front and rear wheels depending on what wheel you have. This all means a trip to your local bicycle dealer. They will match the pedals to the axel size you need and the type of riding you will be doing. For a little extra cost they will install them.They will also match you up with the proper length of quick release skewer you will need and show you how to install and tighten it properly.Remember to take your bike and the front wheel. Hope this helps. Good riding.
Mar 15, 2009 | Schwinn Midmoor Men's Hybrid Bike
Mens Titan Pathfinder Mountain Bike
If the gears will no longer go back on the bike, I would recommend buying a new wheel (including a new rear hub). It is usually easier and more cost effective to buy a wheel than to replace the hub. To replace the hub (the part that is stripped on your bike) you would also have to remove and replace spokes, etc. Search online for the wheel size you need (probably 26" - you can check the tire size) or take to a reliable bicycle shop and they will gladly help you. Anyway, you need a new hub but probably better off getting a new wheel - much easier.
Feb 14, 2009 | TitanNet Bike USA Titan Pathfinder Ladies...
Cycling Logo
88 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
