I have a 2010 whirpool cabrio. No agitate No Spin fault as it senses the load. No LED display on this model. Is there a roary postion sensor on the belt driven model wtw5500xw0 ? If so, part # ?
robocop
  • 90 Answers
SOURCE: Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
Posted on Jan 19, 2009
mark_37388
  • 100 Answers
SOURCE: No agitation or spin
You have a broken motor coupling between the motor and the transmission the washer should still drain if you put it in spinn just not spin the tub
Posted on Apr 15, 2009
  • 61 Answers
SOURCE: won't spin or agitate
replace coupler between motor and transmission
Posted on Sep 29, 2009
TheMobilian
  • 8220 Answers
SOURCE: F-1 F-1 Code Comes on.
Cabrio page 66 F-1 control failure replace main control
Posted on Aug 16, 2010
richroth
  • 9472 Answers
SOURCE: kenmore 28731 top load washer
You will need to replace the motor coupling. Here is a video to show you how to do it.
Posted on Oct 12, 2011
How do i get codes for a whirlpool cabrio wtw5500xw0 washer with no display?
Error codes for WTW5550XW whirlpool cabrio
It would appear that no one read your original post, I believe you asked: HOW DO IT GET THE ERROR CODE. I have the same machine and had the same problem. The method is descibed in the service manual available at servicemanuals.net for about $17. It also has a decent wiring diagram and how to generally do anything the local service guy could do well worth the money for a download you can have in your hands in minutes.
Back to your question.1) turn the washer off (the power button) all the indicator lights should be off.
(now think of your old gym locker combination lock, cause it will be a little like this)
2a) rotate the center selector knob CCW (counter clockwise a few clicks), this seems to get the machines attention
2b) immediately rotate 1 click CW clockwise
2c) immediately rotate 1 click CW (again)
2d) immediately rotate 1 click CW (again)
2e) immediately rotate 1 click CCW
2f) immediately rotate 1 click CW (again)
visually it would look like this <---,->,->,->,<-,->
now just the led's below the indicator should be blinking off and on on about 1 second intervals
you may need to try a few times to get the timing just right, you aren't spining through the clicks, just about enough time to say "left-left-left-right one,right-two,right three,left one, right one
with all the led's in a row blinking you are ready to go into code mode.
(sensing soak wash rinse spin done) (mine doesn't have soak BTW)
3) rotate the selector knob a few clicks until only the "done" led is lit
4) press start
5) the led's should blink again
which leds blink tells you alternately the fault# and error# when the "sensing" led is blinking, the other leds are indicating the fault number, when it is not on, the indicate the error# the fault# is the type of problem, and the error# indicates where the problem was detected.
6) a partial listing using the fault #, I will indicate the led as follows: Sensing/Wash/Rinse/Spin/Done
S/W/R/S/D this would be all these leds lit
s/w/r/s/d this would be all these leds off
the F# codes to the right is what you would see if you had the numeric display on the console (not all models)
Here goes:
Over suds condition: S/w/r/s/d F0
High water temp rinse cycle: S/w/r/s/d F0
Off balance load: S/w/r/s/d F0
Main control fault: S/w/r/s/D F1
Motor control fault: S/w/r/s/D F1
Stuck key: S/w/r/S/d F2
Mismatch of main control UI: S/w/r/S/d F2
Pressure sensor fault: S/w/r/S/D F3
Inlet water temp fault: S/w/r/S/D F3
Lid switch fault: S/w/R/s/D F5
Lid lock fault: S/w/R/s/D F5
Lid unlock fault: S/w/R/s/D F5
Lid not opened between cycles: S/w/R/s/D F5
Basket speed sensor fault: S/w/R/S/D F7
Shifter fault: S/w/R/S/D F7
Motor fault: S/w/R/S/D F7
Motor unable to reach target rpm:S/w/R/S/D F7
No fill long fill: S/W/r/s/d F8
Overflow: S/W/r/s/d F8
Hot cold reversed: S/W/r/s/d F8
Long drain: S/W/r/s/D F9
yes several of these had identical blinking light combinations, but it is good start.
Apr 21, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
What does F 51 mean?
The F51 fault code on your Cabrio washer indicates that the control board is not sensing the proper drive motor spin. To clear the fault code, press the Pause/Cancel button.
Make sure that the drain hose is not stuck way down the stand pipe. This can cause siphoning of fill water which will inhibit proper motor rotation.
Check to see if the wash basket spins freely. If it does not, you may have an item of clothing stuck between the outer tub and the inner basket. This restriction in rotation will also cause an F51 fault code.
If these tips do not help you resolve the F51 problem, then you probably have a component failure. Possible failures include: wire harness or wire connection problem between the machine control and the RPS sensor (Rotor Position Sensor), a failed RPS sensor, a failed drive motor, and a failed machine control board.
Mar 08, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
OUR WHIRLPOOL/CABRIO MODEL WTW6600SW2 IS FLASHING F1. WHAT IS PROBLEM?
Lool on this site for F1 fault. Apparently a very known problem, seems with control pcb. I called Whirpool today on a machine purchased in 4/07 with a 4 year extended warrenty from Lowes, and they didn't even question it. Said a repairman would be out to replace part and parts and labor are covered by Whirpool. Call them at their 1800 #, Mention it's the infamous F1 fault, have model and seriel # at rear of top load door ready for the technical help person, and they'll take care of it.
Dec 08, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a f50 fault code on my cabrio washer it won't spin or agitate.
F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation. ? Does basket turn freely? If not, make sure bottom shipping pack has been removed. Determine cause of friction.
Apr 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio won't spin
F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation. ➔ Does basket turn freely? If not, make sure bottom shipping pack has been removed. Determine cause of friction
its SD not 5D
Sd is displayed when the machine/motor control, by analyzing drag on the basket, detects a suds-lock condition, and is steady on while the control then runs a mini-clean out cycle. If the clean out cycle is unable to correct the over-sudsing problem, the cycle ends and Sd flashes in the display. This may signify: ➔ Load is bunched or twisted around agitator. ➔ Excessive detergent usage. ➔ Basket cannot engage during drain step. ➔ Mechanical friction on drive mechanism, not allowing basket to engage.
Jul 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirpool cabrio top load washer 1.5yrs old flashes FXX error code
Try this:
  1. Switch off the power using the 'MAINS ON/OFF' button
  2. Press and hold the 'Temperature' button
  3. Carry out the next three steps within 3 seconds;
  4. Switch on the power
  5. Release the 'Temperature' button
  6. Press the 'Soil type' button
  7. Check that a message similar to "DIAGNOSTIC MODE 123F7F2F5V127" is displayed. If it is not, repeat from the beginning
  8. Switch off the power
  9. Switch on the power. The fault code should have cleared.
Dec 10, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
