Were do i get my Password for Rooter Dlink DWR 730 3e61
    Master:
  • 425 Answers
Go through the manual or connect it for the first time you would get the PDF manual. Often times the initial factory password is admin or 1234.
Posted on Apr 24, 2017
How do I change or find out my password to connect to the internet?
You can access the administration of your rooter with a browser on your computer: often it is http://192.168.2.1 but it change according to the company. The user is "admin" with no password if you haven't changed it.
You can also reset your rooter with a trombone in a hole at the rear. it will be reset without any password.
If you have a rooter provided by a company like Bell or AT&T, ask them to reset the password.
Write your password on a paper !!!
Jul 01, 2014 | Apple iPad Mini
DWR-113 router, how do I change the password so others can't connect to it?
Here is the manual:
http://files.dlink.com.au/Products/DWR-113/Manuals/DWR-113_A1_Manual_v1.01(WW).pdf
Apr 27, 2014 | D-Link Computers & Internet
For some reason I can't seems to concent to the wifi in my house.
Try rooter factory reset and conect witout password then reconfigurate rooter setings.
Feb 13, 2014 | Computers & Internet
One sim will work in the D-link DWR-730 firn but when I put in another sim that is working fine in another device, it won't work. I can log onto the d-link but you cannot get onto the web
I do have the same problem. All works fine except it stays "disconnected" and no way to change that.
Also I found no way to put or change the number to be dialled in the DWR-730 to connect to a service. Normally it needs to dial *99# for the operator I am using. I guess our problem is only that.
Who from Dlink can tell us how to access the modems dial string?
Apr 03, 2013 | D-Link Computers & Internet
How can I change wireless password?
from your rooter administration program/file.
you need to log in into ur rooter. Ussually in a browser : http://192.168.1.0 or 192.168.1.1 or 192.168.0.0 or 192.168.0.1
Login in there with ur custom username and password (you should have them on ur rooter manual. (try user: admin and password: admin it should work.)
May 02, 2011 | Computers & Internet
Dlink help!
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Oct 20, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
The linksys wrt54gs-uk
With a DSL modem in the US, you need to confiugre the router for PPPOE with the username/password that was provided to you by your ISP. If you can't remember the name or password, contact your ISP
May 31, 2009 | Linksys Wireless-G Broadband Router
Needed to secure my dlink dwr 655
ok...
first you need to find the default gateway of the router,u need to do this settings in the computer which is wired to the router,securing the network over a wireless connections is not suggested..
click on start,run,and type in cmd,hit enter,a black box should appear in that box type in ipconfig and hit enter,once you hit enter it will give u a lot of results check the default gateway the generic default gateway is 192.168.0.1,might be different in your case incase if you have setup in a different manner,now open an internet explorer page and remove the website name that present in the addess box,now without http or www type in the numbers,it will tell you to put in the user name and password,username is blank and password is admin (this is generic to all the delink routers provided you have not changed it earlier,if u ave changed it then put in the user name and password that you have setup,now it should open a dlink router page,now in that router page you will see an option that will says wireless,under wireless you will see an option that says security,click on security,and then under security page you will see security mode,from here you can use the security type that you want to use and then save the changes once it has saved the changes you wireless netwokr will be secured.
PS:make sure the computer is connected with a wire to the router when we are setting the security in the wireless network....
vedhick.........
Feb 21, 2009 | 2wire Computers & Internet
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
