Question about Refrigerators
We have a HJA 6110 American fridge freezer, how do I replace the Freezer motor.
    Top Expert:
  • Refrigerators Master
  • 12,962 Answers
You remove the refrigerant, remove and replace the compressor with new one, install a schraeder valve and using a vacuum pump remove all air from system to -30 lbs and turn off pump to make sure that the pressure holds and there are no leaks in piping. Then charge unit with the correct amount of refrigerant (Critical) and you are good to go.
Posted on Apr 24, 2017
Ice cube dispenser not working
Hi there, did you find the answer to this problem? We have exactly the same issue. We noticed a burnt smell in the freezer, mainly transferring to our hands when we touched packaging. The ice dispenser was working fine but the ice started to taste funny (a bit like burnt plastic) and had black bits in it. We took it out to clean the tray and since putting it back in, it just won't work. We don't know if we have put it back in wrong or if something has blown. We can still hear the motor when we try to press for ice, but nothing comes out. No water is making its way into the ice cube tray to form the ice, but we still have cold running water. I would be so grateful for any help. Thanks
Mar 16, 2014 | Ovens
We have a whirlpool american fridge freezer leaking gas the engineer has been out 3 times , firstly we were told that the motor had blew one of the boards was replaced didn't work then motor repla
No! Gas leakage is only caused by bad joints, stress cracks or holes in the pipework. Also bad seals on the compressor.
The only 'motor' is the condenser fan motor. The other sort of motor is the Compressor.
I would cut your losses, ask them to recover all the parts installed and give you credit and buy a new refrigerator. The reasoning is that their diagnosis did not fix the problem.
Jan 13, 2018 | Whirlpool ET1FHTXM Top Freezer...
Motor noisy, stops when open refrigerator door
i had this problem then turned off fridge freezer for 24hrs and it was gone it was more or less needing defrosted
Apr 29, 2010 | Samsung Refrigerators
American fridge freezer siemens KA58NA50GB. Freezer not freezing
If you are not capable to do that much better to call service Engineer to avoid big damage of your Freezer.
Apr 03, 2010 | Freezers
I have a samsung SR-S2028cvw American style fridge freezer. The temperature on the dials are at the coolest but both the fridge and freezer are warming up to the warmest temperature before the motor kicks...
Try hoovering the cooling rad on the back of the fridge freezer, as this tend to clog up with dust and other matter, which reduces the cooling efficiency
Feb 28, 2010 | Samsung Refrigerators
Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
May 17, 2009 | Samsung Refrigerators
Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Apr 01, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
