Question about Tablets & eReaders
How can i update software for Hero X tablet - Tablets & eReaders
My samsung galaxy tablet is constantly saying i need to do a software update and various apps have stopped working. Have i deleted somethoing important by mistake??
have you tried shutting it off,take the battery out for 1 minute, put it back in & turn it back on.this works for my phablet.
Oct 13, 2016 | Samsung Tablets & eReaders
How can update my hkc tablet
I suppose you want to update to a higher Android version. I advise against it if you are a novice. First, you have to find an updated version of the ROM for your tablet specifically. Then, you will have to use an appropriate software to flash the ROM into your tablet. There is always a danger of bricking your tablet when flashing.
Jan 20, 2015 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
How can I update my iPad 2 with model MC769LL
My iPad 2 is running 8.1.1. Under settings General software update is the second heading.Try hitting the top of the page marked with a left pointing arrow.
Nov 30, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Update ipad
Go into settings, under the General page on the right. You will see at the top, "Software Update." Click that, and if a software update is available, you can download it from there. Just follow the prompts.
Aug 31, 2014 | Apple iPad 32 GB 3G Tablet PC
How to update ios 7 .1 .2
It means a software update for your device is not available, it all depends on your device and how old it is. Just because a ipad air may have the latest IOS this does not mean a ipad 2 generation will have the same software
Aug 02, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
Mar 13, 2017 | Ainol 10" Novo 10 Hero 16GB Dual Core IPS...
My ainol novo hero is frozen on home screen
The simple way to tempary solve this problem by just use a pin to insert to the small hole next to the power supply hole.this will turn off the set and start from begining(not reset to factory setting).If your problem back again then need to consider to go to backup and reset to reset to factory setting.It will lose all your data.If still not work contact the factory and install update firmware./
Jan 22, 2013 | Ainol Novo 10 Hero 10 Inch Tablet Pc IPS...
Cannot update software/firmware
Samsung Tab needs Kies software to update to latest firmware.
Download Kies from here and install it. When finished, launched the Kies and it should tell you whether there's need for an update or not.
Hope this helps.
May 05, 2011 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
