What have you done to your stains?..EVERYONE I get is like "muddy water"..there is no stain quality, they certainly don't stain,.no body! Ive been using Minwax stains and finishes for over 30 yrs.
No staining quality no matter which colour I get....they're just like oily water!
SOURCE: Dark brown stains
the rear tub bearing is shot and will have to be replaced you have to replace the whole rear tub. the brown marks are coming from the spider shaft assembly its rusted out you will have to replace the whole stainless steel tub.
Posted on Jul 09, 2008
  • 261 Answers
Grease will not come from the interior of the washer, as the machine ages build up deposits under the basket and it is oily, greasy and full of mildew. If can get a spanner wrench from a appliance parts house and remove the basket you will see on machines older than three years a build up starting. I pulled 15 lbs from a 25 year old machine and I had to go get sick outside, it was bad.
Posted on Oct 06, 2008
  • 115 Answers
SOURCE: hoover 800 RL toploading washing machine
if you use liquid fabric softner that is what it is sort of looks like grease what happens is that softner gunks up and gets up under the agitator then when your lighter clothes are washing it shows up you need to take some stuff called washer magic and just follow the directions on the bottle
Posted on Jan 01, 2009
  • 88 Answers
SOURCE: Stains in my thermocast sink
Rinse after every use. Sanatize with Bleach once a month. Use a soft cloth or sponge and liquid soap to remove residue. Scratches can be buffed and polished with a liquid based auto polish to maintain High Gloss finish. Do not use abrasive cleaners which will dull the finish. If you have used the sink in a non-normal usage and stained it, it can not be repaired under most circumstances. If you have not voided the warranty, you may be eligible for a replacement from the company.
Posted on Apr 16, 2009
SOURCE: how to remove smoke stain ?
I just cleaned ours yellow stain using a metal/chrome cleaner, a "magic eraser", and a lot of elbow grease. It still has a yellowish tint but the cleaning made a BIG difference. I hope it works for you!
Posted on Jul 25, 2009
Can I use a oil base primer such a as kills over a oil base stain ?
yes u certainly can it will take care if it the next day primer it just sand it a little if your stain doesn't look good stain it again or put some stain in polly urethane and brush it on they do sell poly with stain already mixed
Jan 14, 2018 | Cars & Trucks
What can I use to remove a stain of SOYSAUCE in a carpet?
1. Mix one tablespoon of liquid hand dishwashing detergent with two cups of warm water.
2. Using a clean white cloth, sponge the stain with the detergent solution.
3. Blot until the liquid is absorbed.
4. If the stain remains, mix one tablespoon of ammonia (Caution: Never mix chlorine bleach and ammonia - the resulting fumes are hazardous) with 1/2 cup of water.
5. Sponge the stain with the ammonia solution.
6. Blot until the liquid is absorbed.
7. Sponge with cold water and blot dry.
Nov 21, 2014 | Heating & Cooling
How can I clean stains in concrete?
It depends what the stain is. Concrete is porous and like clothing, some stains are permanently set. Detergents remove oils. Surfectants take it a step further. Acid removes scale. Cat litter can soak up standing oil. Once clean to satisfaction, seal the concrete to help prevent future staining.
Jul 22, 2013 | Building Materials
My black crockpot has white stain all inside of it ive tried bleach, vinager, comet and plain old elbow grease, nothing works. Any ideas?
Does it appear that the enamel is worn away and the stain is embedded into the underlying ceramic?
If not, here's a crazy thought for a solution that just might work: Oxiclean. It's safe to put in your dishwasher, and it certainly does a stellar job of getting stains out of practically anything. It works best in warm to hot (but not boiling water), so a scoop in a crock pot full of water set to low for an hour or two may just do the trick. If not, I doubt anything will. Be sure to rinse it thoroughly after cleaning. If you've used Oxiclean before, you know how slick the residue can be.
Hope this helps!
Mar 02, 2011 | Rival SCVC600-SS 6-Quart Slow Cooker
I have rust spots/stains in my bathroom door frame which is alongside my showerwater appears to be getting into the door frame (aluminium not wood) and staining the paint its rust spots so i know its...
aluminium does not rust so the stain will not be rust stains
could be leaking fitting at the plumbing pipes at the taps
could be that the washer under the tap insert is leaking especially if not replaced when doing the spindle seals
May 03, 2017 | Washing Machines
Stain in dryer
This will work. Soak white towel or other white fabric in bleach water, then slightly wring them out, leaving very wet. Then put them in dryer, on low or fluff cycle. Run for 60 minutes or more. This should rub off all the ink in the dryer. You may have to repeat if you have alot of ink. I have done this a few times and it has always work, good luck.
Mar 30, 2009 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
