Camper hasn't been used for a few months. Now the air conditioner won't kick on. Had same problem last year. Took to repair shop. The repairman removed the cover and did something and it worked fine. We don't know what he did.
  • dogwhiskers Jul 24, 2009
    We have checked what you suggested we check with the exception of the capaciters.
    Unfortunately we don't know enough about air-conditioners to know where the capaciters are so it probably isn't safe for us to try to find them.
    We feel certain that this is the same problem we had last year. We do remember the repairman saying that that was a common problem if the air-conditioner hadn't been operated in some time. He mentioned looking for dirtdobber nests but also said there were none. I'm not sure these were his exact words but as I recall, he said it had just "siezed" up. To us it meant that it had just locked up from not having been used. No parts were required.
    President:
  • 2,559 Answers
This could be one of numerous things,best thing to do is just have it checked out again and this time have them right down what all they do for future reference.
Posted on Jul 25, 2009
  • 19,396 Answers
Simply disconnect the AC from power and plug it back. If you have a 30 amp fuse on AC you may remove and put the fuse back.
If that does not work:
Check if there is a relay for the AC, in that case you may need to replace relay.
Ensure that the battery is fully charged, and th, at the inverter is working fine. The camper air conditioner (on US model) requires 120 volts +/- 10% to operate correctly.
There are also two capacitors located on top of the compressor, run capacitor and start capacitor, if one of them has blown the unit will not start. Be careful handling the capacitors, they can release heavy discharges even when unit is not connected to power.
Posted on Jul 24, 2009
Compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
Aug 04, 2012 | Frigidaire FAH106N1 Wall/Window Air...
Why is my air conditioner trowing hot air instead and is brand ne
mcdevito75 here, You may need a charge of freon gas to make the A/C Cold, secially if your A?C unit hasn:t been serviced in 2--3 years. alo chech switches on the unit Fan on 3 Minutes, then Low cool and 1/2 way thru the blue scale shown on the knob. If all is set well, see your local A/C repair shop., they come to the house.
Jun 24, 2010 | Haier Mechanical Air Conditioner HWF05XC7
Unit lights up and hums but does not blow air
mcdevito75 here, Sounds like the fan motor is haging up or needs to be replaced, try the switch on/off then on/off a few times see if the fan kicks on, if not see your local a/c repair shop, they come to the house.
Jun 22, 2010 | Whirlpool ACQ158XP Wall/Window Air...
On my 1999 camper trailer when I turn on the dc powered lights while the airconditioning is running the compressor will kick off. If you wait 3 minutes it will come back on and continue to work fine until...
Welcome to FixYa
Not enough cooling complaints are due to air flow issues, and not lack of “Freon.RV air conditioner- come from the factory- are hermetically sealed.The first basic area is the air filter. In summer, using the RV and air conditioner around the clock, the filter should be checked weekly and cleaned as needed. RV air conditioners use either a foam type filter or a fine mesh, both of which can be rinsed in water and reused.keep the filter(s) clean.Few years latter even the best filter will let enough dirt past to coat the evaporator coils, though, so they need to be cleaned. If the coils are not too dirty, and if the installation leaves enough room to access the coils.Once the cover is off, you can see the evaporator coil -Clean Coils too...
Thanks for Contacting FixYa....
Jun 10, 2010 | Dometic Rooftop RV Air Conditioner
Unit turns on but condensor dont kick in
Need to pull the cover off and see if the compressor is comming on.If not have someone with electical experience check the contacter.Sometimes bugs will get under the contacts durring wenter.If it is running the freon is low
Jun 27, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
When turned on, the unit sounds like it will start then turns off within a minute.
Presently according to my information there is no recalls for Fedders products at this time for this model type.
May 27, 2008 | Fedders A&B Chassis A1A07W2B Air...
Air conditioner
Unit is low on Freon. Take it to a repair shop to find the leak & recharge the unit.
Jun 18, 2007 | Haier Mechanical Air Conditioner HWF05XC7
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
