E mail accountcantset it up - Computers & Internet
Setting up windows mail
Use this.. Yahoo Incoming Mail Server (POP3), pop.mail.yahoo.com (port 110) Yahoo Outgoing Mail Server (SMTP), smtp.mail.yahoo.com (port 25)
Good luck. Thank you for using FixYa.
Jun 08, 2010 | Yahoo Mail
I can recieve email but I cant send any email out
If you can successfully receive e?mail messages, but can't send messages, then Windows Mail is having problems connecting to the outgoing e?mail server that's used to send messages. These are likely possibilities:
  • If you've never been able to send e?mail successfully using Windows Mail, your e?mail account is probably not set up properly. First, follow the steps to verify your e?mail account information in the "I can't receive e?mail" section of this help topic. If you verify that your e?mail account information is entered properly, you might need to change your authentication settings so that when sending mail, you sign in using your e?mail user name and password. Check with your e?mail provider to see if it requires authentication for sending e?mail.
    To use authentication when sending e?mail
    1. Open Windows Mail by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking All Programs, and then clicking Windows Mail.
    2. Click the Tools menu, and then click Accounts.
    3. Under Mail, click your e?mail account, and then click Properties.
    4. Click the Servers tab, and then, under Outgoing Mail Server, select the My server requires authentication check box.
    5. If the account information that you use to send e?mail is not the same information that you use to receive messages, click Settings, click Log on using, and then enter the user name and password that you use to send e?mail.
  • Many Internet service providers (ISPs) require you to be directly connected to their network to use their outgoing e?mail servers. If you're using a mobile PC and connect to the Internet using a different ISP (such as when using a wireless connection in a hotel), you might be able to receive, but not send, e?mail. Some ISPs will allow you to send e?mail when connected to a different provider if you use authentication when sending. Follow the previous steps to use authentication when sending e?mail. If your ISP doesn't allow this, you'll need to find out the name of the outgoing mail server for the ISP you're currently using, and then change the settings in Windows Mail to use it.
    To change the outgoing mail server settings
    4. Click the Servers tab, and then enter the new mail server in the Outgoing Mail (SMTP) box.
    5. If the new outgoing mail server requires authentication, under Outgoing Mail Server, select the My server requires authentication check box.
    6. Click Settings, click Log on using, and then enter the user name and password for the outgoing mail server.
Mar 27, 2010 | Yahoo Mail
I can't send or get e-mail when trying to use outlook on my touchpro 2
Try again make this settings my friend
The Mail tab is where you send and receive e-mail messages. Including Outlook E-mail, you can add up to four POP3/IMAP4 and web-based e-mail accounts in this tab.
To add an e-mail account
1. On the Home screen, slide your finger to the Mail tab.
2. If this is your first time to add an e-mail account, touch New Account on the bottom-right side of the screen.
3. Set up your e-mail account using the E-mail Setup wizard.
4. To add another e-mail account, touch Menu > Accounts > New Account and use the E-mail Setup wizard to set up your account.
For detailed instructions on setting up e-mail accounts using the E-mail Setup wizard, see Chapter 6.
To check e-mail
When there are new e-mails, the icon on the Mail tab and the respective icons of the e-mail accounts will show the number of newly received messages.
If you have installed the synchronization software on your computer and created a partnership with your device, then your device is ready to send and receive Outlook e-mail.
If you have not yet installed the synchronization software nor created a partnership, do so by following the procedures in Chapter 5.
Tip To set up your company e-mail account so that you can access Outlook e-mail messages wirelessly, you must set up your device to synchronize via an over-the-air connection with your company’s Exchange Server. For more information about synchronizing with your company e-mail server, see Chapter 7.
Add an e-mail account
To add a new e-mail account, you can do one of the following:
On the TouchFLO 3D Home screen, slide to the Mail tab and then touch Menu > Accounts > New Account; or
Tap Start > Messaging > Setup E-mail.
The E-mail Setup wizard then opens and lets you enter your e-mail account settings. See “E-mail Setup Wizard” in this chapter for details.
Jan 11, 2010 | HTC Touch Pro Smartphone
Hi I am trying to set up my mail on my apple computer and I am able to receive mail from it but not send mail, in order to do so I have to go to yahoo mail and do it from there
Sounds like your "Outgoing" mail server settings aren't correct.
Yahoo! E-Mail Server Settings
Yahoo Incoming Mail Server (POP3) - pop.mail.yahoo.com (port 110)Yahoo Outgoing Mail Server (SMTP) - smtp.mail.yahoo.com (port 25)
___________________________________________________________
POP Yahoo! Mail Plus server settings
Yahoo Plus Incoming Mail Server (POP3) - plus.pop.mail.yahoo.com (SSL enabled, port 995)
Yahoo Plus Outgoing Mail Server (SMTP) - plus.smtp.mail.yahoo.com (SSL enabled, port 465, use authentication)
Jan 04, 2010 | Yahoo Mail
What is the POP 3 address to send email using instead of using wi
You simple CANNOT. Windows Mail no longer supports the HTTP servers used by Yahoo! and other web-based e-mail providers. Windows Mail does not permit the use a Web-based (HTTP) e-mail account on a computer that is running Windows Vista.
For an alternative, use Windows Live Mail instead of Windows Mail
loadTOCNode(3, 'resolution'); Windows Live Mail is an e-mail program that you install on your computer. Windows Live Mail stores messages on your computer. This means that you can access, read, and compose e-mail messages even when you are not connected to the Internet.
Windows Live Mail works with popular Web-based e-mail services such as Hotmail, AOL mail, Google mail, and Yahoo! mail. Windows Live Mail is built to automatically configure many popular e-mail services.
To install Windows Live Mail, visit http://download.live.com/wlmail
Jul 25, 2009 | Microsoft Windows Vista Home Basic Edition...
What incoming and outgoing mail server info. do I need to set up
Hi, For yahoo mail you need upgrade to yahoo mail plus (@ $19.99 per year) to get the full pop3 service for access to Outlook,Incredimail, Thunderbird and others.
For more info on setting up your pop3 account see the links below.
http://help.yahoo.com/l/us/yahoo/mail/cl...
* Incoming Mail Server (POP3): plus.pop.mail.yahoo.com
Use SSL, port: 995
* Outgoing Mail Server (SMTP): plus.smtp.mail.yahoo.com
Use SSL, port: 465, use authentication.
If you have “yahoo.co.uk” address some users can get free pop forwarding see below.
Click “options” (top right) on your mail page>mail options>pop and forwarding>
Set up or edit pop & forwarding>type in the address you want to forward to and
click save.
* Incoming mail server (POP3): pop.mail.yahoo.co.uk
Use SSL, port: 995
* Outgoing mail server (SMTP): smpt.mail.yahoo.co.uk
Use SSL, port: 465.
Note: In order to be able to send emails from outlook and others through/to yahoo (pop3) you need to pay for a yahoo mail plus account.
http://help.yahoo.com/l/uk/yahoo/mail/cl...
Apr 10, 2009 | Yahoo Mail
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
