Question about Locks & Locksmithing
I have a gordon digital safe item #45891. I changed the batteries and now nothing works. No lights or anything. How do I rest it?
2 Suggested Answers
SOURCE: gordon item#45891 digital safe, lost code the door is open
there is red button on the inside of the door (hinge side) press this , then key in a new code
Posted on Oct 10, 2009
How to open Gordon safe 45891 when the back up key won't turn
yeah,do the only thing you can do with a safe,,,,,call gordon safe
Jul 06, 2015 | Locks & Locksmithing
How to open a Gordon safe 45891 when the key and handle won't turn
STOP SPAMMING!!! NO WONDER THE SERVERS ARE OVERLOADED!! GEESH!!,READ THE OTHER QUESTIONS ANSWER!
Jul 06, 2015 | Home Security
Where does the override key go In on 45891 I took paper off front and there is a circle disk we cannot get off any ideas? We can not open it the green light comes on but it won't turn
Here is the manual for the Harbor Freight 45891 digital safe. Please refer to page 4. http://images.harborfreight.com/manuals/45000-45999/45891.pdf
Dec 13, 2014 | Computers & Internet
I have no owners manual . None in the box when I got the item.I dont know how it works or if it is working properly. The 2/10/25 AMP charge button doesn't seem to do anything . Nore does the 75 AMP start...
Gordon, Not sure why this came up under chain saws. However I think your talking about a battery charger. There are some battery charger that when powered on but not connected to a battery will not produce a voltage or current. This is to protect the charger from shorting if the cables touch. Once connected to a battery and it see a little voltage from the battery it will enable its charging circuit. Make sure the battery you are attempting to charges is not completly flat.
Hope this helps.
Nov 10, 2010 | Garden
Opening the Gordon Digital Safe #45891 with dead batteries.
Just did this with my same safe for same problem. It worked! Great..just pulled the whole front off first but whatever!
Mar 18, 2010 | Safe International Digital Electronic Safe...
Gordon item#45891 digital safe, lost code the door is open
Oct 07, 2009 | Safe International Digital Electronic Safe...
I have a model 45891 Bunker Digital Safe. Battery
how do i change combination on bunker hill 45891 safe, i have tried every way i can think of.
Oct 05, 2009 | Check Point Network Adapter
I have a gordon digital electronic safe # P45891, lost combination .how to open it?
Take the single screw off of the entry pad and remove the cover plate. Using the key that came with the safe, unlock the safe. Now, look for a little red button on the inner hinge. Push it in and you will note the yellow led on the the front of the safe turns on. Now, enter a 4 digit code of you choice. This is automatically saved and is the new 4 digit code you press to open the safe.
Jun 30, 2009 | Safe International Digital Electronic Safe...
Resetting code
Go to harborfreight.com; click on safes picture in the right column; then click on the safe that you have (#45891); then click on the instruction manual download icon at the bottom. This should solve all your problems.
Feb 16, 2009 | Safe International Digital Electronic Safe...
Bunker hill digital safe
CHANGING CODE ON MODEL # 45891:
On the inside of the door toward the hinge, you will see a small red button. Press this button until the yellow light on the front control panel lights up. Now you can imput the new code (1 to 8 digits) into the front control panel, followed by either the "A" or "B" key. The safe will beep twice (2 times) to confirm the code has been changed. Important: If the safe beeps 3 times, then the code has not been accepted and you must repeat the above steps.
DO NOT LET THE BATTERIES RUN OUT BECAUSE YOU WILL NOT BE ABLE TO OPEN THE SAFE OR CHANGE BATTERIES.
Dec 19, 2008 | Check Point Network Adapter
Locks & Locksmithing Logo
133 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
