1camera 1000 how to install without y cable - Computers & Internet
Tip
EZ steps to install HP printer in Windows 7 without Installation software
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select approriate drive from below list provided and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Determine the appropriate compatible driver
Deskjet 3320, 3325, 3420 and 3520 -------------Deskjet 3600 *
Photosmart 7600 series------------------------------ Deskjet 5600
Deskjet 5850 ---------------------------------------------Deskjet 5600
Photosmart 130, 145, 230 and 245 ---------------Photosmart 330 *
Photosmart 7350 and 7550 --------------------------Deskjet 5550
Deskjet 6122 and 6127 --------------------------------Deskjet 990c *
Deskjet 3820 -----------------------------------------------Deskjet 970cse *
Deskjet 656 ------------------------------------------------Deskjet 660c *
Business Inkjet 1100d ---------------------------------Business Inkjet 1000
Business Inkjet 1100dtn ------------------------------Business Inkjet 1000
Deskjet 9300 ----------------------------------------------Deskjet 1220c *
Deskjet 9650, 9670, 9680, 9680gp---------------- Deskjet 9800
* Available only through Windows Update.
(Happy Printing)
Regards
Rizwan
on Jan 29, 2010 | Office Equipment & Supplies
How do i install this?
  • Place the product installation CD in the CD drive of your computer. The installation wizard will start automatically. Follow the installation wizard prompts.
  • Plug the USB connector at the end of the LifeCam VX-1000 connection cable into an available USB port on your computer when prompted.
  • Place the LifeCam VX-1000 on a flat, level surface, or hang it from your computer's monitor. Continue following the wizard prompts until the installation wizard finishes.
  • Click the "Start" button, then click "All Programs" on the Start menu.
  • Click the "Microsoft LifeCam" folder icon in the list of programs on the Start menu, then click the "LifeCam" icon. That opens the LifeCam VX 1000 software and completes the installation process.
  • Dec 23, 2010 | Microsoft LifeCam VX-1000 Webcam
    Wht should i do to conenct to internet
    1. Uninstall or disable all Internet-sharing applications, proxy software and security software such as anti-virus programs or firewalls. Although every program is different, if you choose to uninstall one, you can typically do so by clicking "Start," "Control Panel" and "Add/Remove Software" and then selecting the software you wish to remove. Because Homeportal 1000 comes with its own versions of these programs, this step is essential to avoid conflicts.
    2. Connect Homeportal's AC power adapter to the back of your router, and then plug it into a power outlet. The green power light should come on.
    3. Connect the router to your
    computer. If you're using Ethernet, connect the Ethernet cable to both the router and the Ethernet jack on the back of your computer. If you plan to use USB, follow the same procedure using the USB cable and ports, instead. For a wireless connection, ensure that your wireless card is correctly installed on your PC.
    4. Connect the phone cable to the back of your router and then plug it into a phone jack. This will allow the Homeportal 1000 to receive DSL signals from the phone company.
    5. Place the Homeportal 1000 installation CD into your CD drive and follow the on-screen instructions to install the necessary software and until finish installation.
    We are now ready to browse a website.
    Dec 22, 2010 | 2wire HomePortal 1000 Router
    How to install a vx 1000 webcam without the disk
    Hi
    You can download the drivers from the below link and you can install it
    http://www.opendrivers.com/searchopendrivers/VX-1000.html
    THANKS....
    With Regards......
    Vaishu
    Sep 26, 2010 | Microsoft LifeCam VX-1000 Webcam
    Linkskey LKS-SG8P Cant get 1000 mbps light with
    Yeah, at that length you might need CAT6, I have used 5e with up to 45 feet without problems though.
    Sep 19, 2009 | Linkskey Computers & Internet
    Microsoft LifeCam VX-1000 cant install
    http://www.microsoft.com/hardware/download/download.aspx?category=ICE
    go to that website then click down on the drop down list and select your product in your case webcam then on the next drop down list select lifecam vx-1000 then on the next one select your operating system and then on the last one select your language and then click go it will take you to the site where you can download your drivers
    Jun 02, 2009 | Microsoft LifeCam VX-1000 Webcam
    My harmony 1000 remote is not recognized by my mac computer
    I had the same problem today on PC with the Harmony 1000. I noticed on the USB cable that mine came with it had a warning red icon (!). 1. install software then 2. plug in USB...
    I didn't see this and I installed my software whilst the device was in the charging cradle with the USB cable plugged into my PC.
    Before the software was installed I noticed the USB icon next to the Help on the remote screen, this dissappeared when the software finished installing the software and drivers.
    I removed the remote from the cradle, pulled the battery out, unplugged the USB from the remote and computer, restarted my PC, powered on the remote, started the software on the PC and then plugged the USB into the remote and then the PC.. it was then recognized.
    Mar 14, 2009 | Logitech Harmony 1000 LCD Touchscreen...
    I have a HP LJ 3600 dn that wont' print
    http://www.hp.com/#Support
    Follow the link and get the correct driver and get installed
    Also try with another USB cable, If you are using a long cable, just try with a short one.
    Nov 18, 2008 | HP LaserJet 1000 Printer
    Computers & Internet Logo
    David Payne
    David Payne
