Question about Casio Office Equipment & Supplies
My calculator casio fx-82ms on switch not working but when I removed the battery and fix again then display is on without on switch ? Please help me how solve this problem.
  • 8068 Answers
SOURCE: how do i calculate permutation in fx-82ms casio
Find on the calculator the [nPr] key either (you may have to use the [2nd] or [2ndF] key) then
1. Enter the number that corresponds to n eg. 18
2. Press the [nPr] key
3. Enter the number that corresponds to r eg. 5
18[nPr]5 gives 1028160
If you calculate combinaitions use [nCr] key.
Hope it helps
Posted on Sep 06, 2009
  • 8068 Answers
SOURCE: PLEASE HOW DO I CHANGE MY CASIO FX-82MS
Use the FIX display format and set the number of decimal digits to be displayed to be 2 o 3 or more depending on your needs. Instructions are on screen capture below. Hope it helps.
Posted on Oct 11, 2009
  • 8068 Answers
SOURCE: i am a casio fx-82MS user. i would like to know
Press [MODE] and select [1:COMP]
Press [SHIFT][MODE] and select [3:Deg]. You can also use rad if the angle you are given is in radians.
To start the conversion
Press [SHIFT][-] (Rec) screen displays Rec(
Key in the radius r , ex: 3 screen displays Rec(3
Press [SHIFT][)] (,) to enter comma separator Rec(3,
Key in the angle in degrees, ex: 57.3; screen displays Rec(3,57.3
Press ) to close parentheses; screen displays Rec(3, 57.3)
Press [=]
Screen displays
Rec(3, 57.3)
X=1.620720961
Y=2.524532346
X and Y are the values of the coordinates.
If angle is in radians, [SHIFT] [MODE][4:Rad] the command
Rec(3, Pi) gives X=-3, Y=0
I just realized that your question pertains to the FX82MS but is listed under the FX115ES (That is quite a difference) So my answer above does not concern you but I will leave it as is should anyone need the answer for the FX115ES.
Look at the enclosed screen capture for the FX82MS
Posted on Nov 16, 2010
Elessaelle
  • 122 Answers
SOURCE: i want to remove rad
For removing SCI symbol press following keys Shift-->Mode-->8-->1.
You can't remove RAD symbol, you can only replace it by DEG or GRA.
Posted on Sep 05, 2011
  • 8068 Answers
SOURCE: How to convert a dinary number to a binary number
Dinary? Never heard that one before. What is a dinary number? Anyway your calculator cannot perform the operations. The Casios can work in Binary (base 2), Octal (base 8), Decimal (base 10) and Hexadecimal (base 16). Some Sharps can do calculations in base 5 (pental).
Posted on Feb 19, 2013
Could you please help me .. Is it possible to calculare irr with casio fx 82 ms? Thank you very much
Internal Rate of Return (IRR) Calculation Using Casio MS ...
? 2:32
https://www.youtube.com/watch?v=7Lvqp_E54Y0
Apr 13, 2015 - Uploaded by Nurul Amin
Internal Rate of Return (IRR) Calculation Using Casio MS Scientific Calculator ... +Nurul Amin i have a casio fx-82ms can ialso calculate IRR?
Discounting Basics on Casio fx-991ES and fx-82MS ...
? 7:24
https://www.youtube.com/watch?v=Xs7rq4JI3mg
Feb 14, 2014 - Uploaded by Sujoy Krishna Das
Discount calculations on Casio fx-991ES and fx-82MS calculators .... Internal Rate of Return (IRR) Calculation Using Casio MS Scientific ...
Jan 10, 2016 | Casio FX82MS Scientific Calculator
How can I reset my casio calculator fx-82ms
There should be a small reset hole! Press this in with a paper clip or similar for about 10seconds
Oct 17, 2014 | Casio FX-82MS Scientific Calculator
How do i calculate the normal probability value, give z-value, on casio fx-82ms
The fx-82MS does not have any built-in functions for calculating the normal probability distribution or its related values. You can calculate it using the defining function or any of a large number of approximations. Alternatively you can look up the values in a table.
Some advanced calculators have the functions built in, and programmable calculators can be programmed to give them. Sadly the fx-82MS is neither.
For more about the normal distribution, see http://en.wikipedia.org/wiki/Normal_distribution
Jan 21, 2014 | Casio FX-82MS Scientific Calculator
Is it possible to solve eqn in this 82ms calculator
Sorry, It is not possible to solve equations on the Casio FX-82 ms. Try the Casio FX-115 ES/ FX-115 ES Plus, FX-991ES/ FX-881 ES Plus C.
Oct 29, 2013 | Casio FX82MS Scientific Calculator
I have casio fx-82MS scientific calculator.which display 'd' letter on the screen.after i switched off the calculator even it wont delete.how do i get rid of that?and is it cause my reaguler...
Most likely you set the angle unit to degree. As long as you do not calculate trigonometric ratios you won't get incorrect results. Switch the angle mode to radian if that is what your calculations require.
Aug 21, 2013 | Casio FX-82MS Scientific Calculator
How can i convert degrees,minutes and seconds to decimal degrees in a casio fx-82MS
Use the DMS key marked degree, apostrophe, double quotation mark.
Lets us call it [DMS]
To enter an angle in degree minutes seconds or hour, minutes, seconds, type in the number of degrees, press the [DMS] key, enter the number of seconds, press the [DMS] key, enter the number of seconds then the [DMS] key. Press = the calculator displays the value in DMS units. If you press the DMS key again the number displayed is converted to decimal degrees.
Example:enter 12 degrees, 15 minutes, and 25 seconds
12 [DMS]15[DMS]25[DMS] =
Calculator displays 12 deg 15'25"
Press the DMS key again and you see 12.2569444
Feb 19, 2013 | Casio FX-82MS Scientific Calculator
How to set casio fx-82ms scientific calculator to radians
Press the MODE key until you get the "Deg Rad Gra" screen. Press 2 to select radians.
May 19, 2012 | Casio FX-82MS Scientific Calculator
PLEASE HOW DO I CHANGE MY CASIO FX-82MS CALCULATOR FROM ROUNDING UP ANSWERS.
Oct 05, 2009 | Casio FX-300MS Calculator
81 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
