Question about Garden
Broadway Academy #281 frame. Screen house set up?I have poles 1 thru 8.....
3 Suggested Answers
SOURCE: I need the instructions to
Follow the bottom diagram, if this is the model you have:
Posted on May 22, 2013
AndrexT
  • 17431 Answers
SOURCE: Where can I get tent poles for a 2 room acedemy broadway tent in zip code 93449
http://www.cabelas.com/category/Tent-Repair-Replacement-Parts/106666380.uts
http://www.tentpolestore.com/
Posted on Aug 19, 2015
Need assemble instructions for A cabin tent
Go to mfg for manual download or try a google search for it. It will have assembly instructions.
Sep 20, 2017 | Sport & Outdoor - Others
Cannot get power thru pole on electric Remington chainsaw
All I can say is bypass the wiring inside the pole.
Oct 10, 2016 | Remington Electric Chain Saw
Torque specs on fly wheel on a massey 281
Flywheel Setscrews 80ft/lbs Flywheel Place Bolts 90ft/lbs Flywheel Housing Setscrews 3/8 UNF (Standard) 36ft/lbs Flywheel Housing Setscrews 3/8 UNF (Durlock) 67ft/lbs Flywheel Housing Setscrews 3/8 UNF (4.2482 engines) 42ft/lbs
Aug 04, 2014 | Cars & Trucks
How do you set it up
Check your manual, or look for instructions online, but the basic plan is...
1. Lay it out so the door faces where you want it.
2. Stake down the corners, yes- even if it is 'free-standing' you usually want to do this.
3. Figure out where the poles go. They usually go through cloth sleeves, or metal rings, or clips or something. They also go in arcs that may or may not cross at the top. (a manual REALLY helps with this!)
4. Slide a pole in place. if it goes through a sleeve, you usually slide it in first, then stick the ends of the poles on little metal studs at the corners. If it clips on, you usually build the pole, then run it from stud to stud, then clip the tent to the arch you made.
5. Repeat for all poles
6. Pull the rain fly in place, clip on at each pole end and as needed.
7. Pull out and stake other ties as available. This gives you more interior room, more stability and protection in weather, and improves ventilation.
May 30, 2014 | ACADEMY BROADWAY CORP Camping, Backpacking...
I have a magellan yukon (23-010) 20'x9' that has some broken poles. Where can I replace the poles
You can replace tent poles. I've never used them, but you can try http://tentpoletechnologies.com/. Otherwise I would suggest buying replacement poles from Academy (who makes the Magellan Outdoor line) or trying to find generic poles and an sporting goods store. Best of Luck!
May 31, 2013 | Magellan Outdoors Yukon II Cabin Tent
I need assembly instruction for 8 person cabin dome tent with screen house
Clean the ground of any rocks, logs or big sticks. Open the stuff sack and pull out all of the contents. Pull the poles out of their pole bag and set them aside. Remove the tent stakes and set them next to the tent.
  • 2 Lay out the tent poles and assemble them. Push the rod blanks together to make the tent poles that will support the mesh tent body.
  • 3 Unroll the mesh tent over the cleared ground. Take care not to step on or walk on the mesh panels. Avoid sticks and snags, as the mesh rips easier than nylon tent fabric.
  • 4 Clip the Timbertop tent pole clips to the poles. There are no tent pole sleeves because Timbertop uses external pole clips for its mesh tents. Criss-cross the tent poles and push the tent pole tips into the metal holes at the end of the pole clip lines. The mesh tent will now be standing upright.
  • 5 Place one tent stake into the ground and through a pole strap stake hole. Pull the tent out as you insert the stake to keep the mesh panels tight. Stake down each pole strap around the perimeter of the tent. Unzip the doors to enter the tent. Zip up the doors quickly after entry to keep bugs and insects out of the tent.
  • Oct 23, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
    How to set up a spalding uv Tex 5 tent
    First set the 3 eleven piece poles with 2 crossed across the tent and one across the front portion. Feed them thru the channels and buckles. Then put the pin hooks into the bottom of the poles. You will need to arc the poles to get the pins into the end of the pole. Next put the poles that are smaller into the channels and buckles for the two vestibules. Again put the pin hooks into the same pole ends as the back crossed one.
    Stake the tent to the ground by driving the stakes thru the pin rings starting at the 6 corners of the tent. Pull front of vestibule taut and secure in place by driving stakes thru webbing loops at base.
    Install the rainfly by draping it over the top of the tent. Hook each of the 8 S hooks onto the provided loops. Secure the rainfly to the poles by wrapping the velcro straps around the poles underneath the rainfly.
    These instructions should be in the pocket on the wall in the main section of the tent in the pocket with red writing.
    Jul 03, 2011 | Rock & Ice Climbing
    I have a greatland tent item #15710. This is a two room tent (not dome) with a screened porch. The poles have numbers and some numbers are blue and some red. I cannot identify whether the numbers go in...
    I am looking for a manual for Greatland Outdoors 2 room tent with screen porch item #15710, however, I guessed how the poles go together. I set up the tent by myself, but I recommend 2 people or more, especially if it is windy.
    Start by stretching out the bottom of the tent into a square, and stake all of the perimeter tentloops to the ground, starting with the corners, with the stakes directed at a 30 to 45 degree angle under the tent, so the tent cannot easily pull them back out. Leave the yellow cords attached to the tentloops loose, so you can use the cords to help pull up the stakes when you take down the tent.
    Now assemble the poles going through the loops across the front of the screen porch. Insert one end of a pole #1 into a pole #2 and thread them through the loops over the entrance to the screen porch. Put the long end of a curved pole #3 through the loops starting from one side, and attach to either side of the 1/#2 you made. Put the long end of another #3 through the loops starting from the other side and attach to the loose end of the #1/#2. You should tie the loose green cords on each corner of the sceen porch to the silver metal rings at the curved end of each #3.
    Later, you will do the exact same assembly with a #3 on each side of a #1/#2 for the poles going across the back of the tent and the poles going through the pocket across the middle/top of the tent.
    Now insert the small end of pole #4 into the curved end of a #3, then insert the small end of a #5 into the open end of the #4. There should be a rubber foot on the bottom of the #5 pole. Do the same thing for the other side of the porch. With help, you should be able to prop up the front of the sceen porch, pulling aganst the stakes holding the rear floor of the tent, and place the rubber feet of the #5 poles close to the center loops of the floor on each side.
    Now prepare the #1/#2 poles for the rear, and attach a #3 to each side and tie the loose green cords to the silver rings on the short ends of the #3s. Prepare a #4/#5 pole the same as the front, and prop up the back of the tent, putting the feet near the side loops of the floor which are about 1/3 from the rear of the tent.
    Make another #1/#2/#3, and push it through the pocket across the middle of the tent, and connect the last #3 from the other side. The side supports for the middle are pole #8 with the white clamp on the bottom, and pole #7 slid into pole #8 (The #7 was scraped off both of mine). Leave the #7 mostly inserted into the #8 until after the center is lifted up. The #6 goes on top of #7, and insert the #6 into the curved end of the #3 poles which are already in the center pocket, and tie the loose green cords to the silver rings at the short end on each of the #3s. Now lift up the center with someone helping on the other side, and put the feet of the #8 into or near the yellow loops at the center of each side. Loosen the white clamps and extend the #7 poles until the peak of the tent is at proper height.
    Move the feet of the #5 poles closer to the tent, until all is tight, and you should be done!
    Jul 21, 2009 | Sport & Outdoor - Others
    Garden Logo
    49 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
