Question about Epson PowerLite 760c Slide Projector
Epson 760 won't print, but there's ink in the cartridges!
My Epson 760 software tells me there's still ink in both cartridges; also the out-of-ink lights are not going on. Nevertheless, it won't print. The cartridges were installed in Feb '07 and the printer is not used much. I've done the check-nozzle and the-clean-the-head functions several times and got test printouts but they've yielded very very faint samples and, now, no printout at all. How can I clean the heads? Would it do to also try to pierce again the cartridge holes (that I assume have dried up). -Guy
  • Guy Cassegrain Jul 24, 2009
    This site should post this under PRINTER and not Powerlite 760c!!!!!!!
  • Epson Master
  • 365 Answers
You may havbe to invest in the cleaner cartridges.
You can try this though.
Bring the cartridges to the middle and unplug machine.
Remove carts and take 5-6 drops of ammonia and put it where the ink would pass through the head.re-install cartridges (Do not plug in)and let it sit an hour or so.
Plug it in and do a nozzle check after the machine has purged itself.
Posted on Jul 24, 2009
  • Michael Grey
    Michael Grey Jul 27, 2009
    Yes it should have been posted in the printer NOT projector category.
My epson xp-200 printer with won't print with the recommended ink cartridge epson 200. why?
The printer may only work with Epson ink cartridges and not compatible ink cartridges.
Sep 15, 2012 | Epson Expression Home XP-200 Wireless...
Ink shows full but color won't print
Uncommon faults are with the electronic drivers in the printer system that drive and control the printer cartridges. This is providing the cartridges are proven to not be defective. Also, jammed nozzles will prevent printing.
Make sure your software is not set to print in monochrome (B&W) only .
Jerry G.
Sep 08, 2012 | Epson Workforce 610 All-In-One InkJet...
My epson printer won't print or scan anything, and can't seem to find the fault. Warning light on the left hand side of the printer indicates that the ink is the problem, so i have checked the inks...
Most likely one of the ink cartridges is out of ink. The Epson printers I'm familiar with all will not print if any one of the cartridges is empty. Most likely it will tell you which cartridge needs replacing.
Oct 11, 2017 | Epson Stylus® DX4800 AllInOne InkJet...
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
Changing ink default to BLACK
Not possible.
Epson uses the black cartridge mostly, but also adds color to the black printing in order to keep the color inks from drying in the print jets on the printhead.
They also make lots of money that way...
===sorry===
Sep 14, 2009 | Computers & Internet
My Epson Stylus Color 760 printer tells me there's still ink
If your ink was installed Feb. 2007, then most probably it got expired as you said you have done test prints but with faint samples.
It is advisable to install new and genuine epson ink cartridge.
Jul 24, 2009 | Office Equipment & Supplies
My printer wont print, and i think theres dry ink in the dispenser, but i dont know how to take it out, because the cartridge holder doesnt come out. i have an epson stylus colour 760. btw, i DID change...
Hi
Try running the head cleaning cycles from printer utility. then try reprinting. You can press ink button for 3secs as well to auto clean printhead.
Hope this helps
Nov 29, 2008 | Epson Stylus C46 InkJet Printer
Epson stylus color 760 failing to print.
you can take it to repair shop and they will clean the head for you with some cleaning fluid if it has been without ink for a while sometimes these get blocked but it is not worth replacing cus would cost more than the printer as the ink cartridge you brought was originall then this isnt the problem check all cables if not better off buying new printer as these are not made to last long sorry couldnt be any,more help...........................
Nov 05, 2007 | Epson Stylus Color 760 InkJet Printer
128 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
