Check reference no A201**********45.i qualify or not
My Ford focus lost power during acceleration and the engine indicator is on. The car also vibrate when you start it.
If the check engine light (as referred to by most ) is lit ,there are codes stored in the engine computer ( PCM , ECM ) that will point a qualified service technician to the problem area . Check Engine Light On
Oct 27, 2015 | 2005 Ford Focus
Tv will not turn on
Check power outlet, try TV on some other outlet. If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation.
Aug 16, 2012 | RCA 32" LED Backlight LCD HDTV
LG FLAT TV, NO SOUND,PICTURE OK
Check for jammed buttons on remote that of volume and mute. Use headphone and check whether that works. Try changing the input device to something that works. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Televison & Video
Toshiba 40FT1U LCD TV has no sound
Check whether same things happen on headphone. Some components are getting excess voltage and heating up. Better to refer it to a qualified service technician.
Jul 24, 2012 | Toshiba 40FT1U LCD TV
Pool heater will not come on and displays a number 4 and service heater
After reading the manual at http://www.jandy-downloads.com/pdfs/H0248900D.pdf, I found the FL4 fault indicates an igniter failure.
The possible causes are:
A. Igniter circuit is open.
B. Element has a fine crack in it.
C. Igniter fault.
The recommended correction is:
A. Check fuses on igniter wires. Identify and correct
loose connections or broken wires. Refer to
qualified personnel.
B. Measure room temperature resistance and
ensure value is in the correct range. See manual
for details. Refer to qualified personnel.
C. Replace igniter. Refer to qualified personnel.
If you have a volt/ohm meter you could measure the AC voltage going to the igniter when it should come on. If you see 120 VAC then replace the igniter. If the ignitor lights up and the gas valve turns on and there is gas pressure then the heater should light up.
If the 120 VAC doesn't get to the igniter you can check the items in the above lists and if not resolved call Jandy technical support at 800-822-7933 and they should be able to help youfigure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 27, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
IT TURNS ON THEN SHUTS OFF,DISPLAY FLASHES SERVICE AGS
Per your owner's manual:
AGS
(automatic gas shut-down)
1. Oscillating pump pressure.
1. Clean filter or identify and repair cause of pump oscillation.
2. Low gas supply pressure.
2. Identify and repair incorrect supply pipe size or pipe line blockage.
Refer to qualified service personnel.
3. No flame at burners.
3. No flame at burners. 3. Identify and correct loose wiring connections, or problems with igniter, flame sensor, gas valve, or ignition control.
For more info the manual is here:
http://www.jandy-downloads.com/pdfs/LXandLT_H02140B.pdf
John
May 29, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
On the jandy 400 lt its displaying the AGS code... what does that mean?
AGS
John
May 03, 2011 | Jandy Laars Lt 400,000 Btu Heater
Code says es1......what is it.... on laarslt heater
1. Flue gas vent switch tripped.
(manual reset)
1. Verify proper fan operation. Check for restriction or
blockage of flue. Reset switch after problem is
corrected.
2. Vent switch fault. 2. Identify and correct loose connections or replace
switch.
3. Fusible link fault 3. Identify and correct loose connections or replace
fusible link.
This happens when the flue gases exceed a certain temperature. This only happens when there is a failed switch, or a bad burn created by incorrect gas or intake air, high wind scenerio or other similar incident to create an incorrect burn.
You may reset the switch manually, but it will most likely happen again, and if it does, its best to call out a technician.
Users manual can be found here:
Apr 14, 2011 | Teledyne Laars Laars LT Heater 400000 BTU...
Power on but no sound
check for a clicking sound of relay after a few seconds from switching on, if missing , the amplifier section needs technical attention. refer service to a qualified engineer.
Nov 14, 2010 | Yamaha R-V703 Receiver
Heater will fire, will heat for one hour then shutdown. will get digital read out AGS. can turn heater off, let set for a while turn heater on will heat up for an hour and it will shutdown again.
you didn't indicate exact model but here is what the AGS is for.
Not sure if yours has a combustion blower or not, if so check that it's flow is not obstructed. If it doesn't make sure there are no debries in the flue area. Here is the troubleshooting from their manual. You can download a manual from www.jandy.com
AGS
1. Oscillating pump pressure. 1. Clean filter or identify and repair cause of pump
oscillation.
2. Low gas supply pressure. 2. Identify and repair incorrect supply pipe size or
pipe line blockage.
problems with igniter, flame sensor , gas valve, or
ignition control.
Jul 16, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
