My hinsense remote is stuck on volume. I can't get to menu. the volume is on the screen it's up to 100. I try to lower it from the side panel on the tv everything seems to be stuck
    Top Expert:
  • Televison & ... Master
  • 74,118 Answers
Try a reset to your TV first. If it do not help, check and replace its main system control memory IC. It is faulty. The fault is with your TV; not with remote control.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Apr 24, 2017
Volume goes max and will not lower.
Hello
Please remove the batteries from the remote and check whether it is possible to use the local keypad on the TV? If the volume increases, it may be a problem in the local keyboard.
Apr 02, 2014 | Samsung LN32B550 32 in. LCD HDTV
My volume display stays on
The Tv needs to be serviced by a technician.Probably there is a problem with the circuits inside.
Apr 12, 2008 | Televison & Video
Sony Bravia stuck in mute
The fault is with its main board itself. It will be best to get this set repaired by skilled technicians. This is not a user repairable one.
Aug 24, 2012 | Sony Televison & Video
The volume stuck on max volume and will not respond to remorol or side panels
Some buttons on remote or on control panel is stuck. Look for it and try releasing them. Remove batteries from Remote and try adjustment from control panel. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Insignia Televison & Video
Vizio VF550M volume stuck at 100
The 2 suspects are possible but there is a way to find it..try to get the control board and remove the vol+ button on it..then back the controller then power it on again try to push vol- on remote or TV..if no help you have faulty main board..
Mar 06, 2012 | Vizio VF550M 55 in. LCD HDTV
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Mar 06, 2011 | Samsung LN32A330 32 in. LCD TV
LG HDTV Volume bar disappeared from Display
try factory reset in main menu or press menu continuaslly until it no longer comes up then 7777 on remote
May 05, 2010 | LG 42LC2D 42 in. LCD HDTV
Front panel buttons and remote have stopped working.
Is the favorite channel menu a function that is normally accessed by a button on the remote?
If so, that button on the remote might be stuck.
If this is the case, the menu may at times pop up all by itself and other buttons on the remote and on the TV's front panel may not respond at all (it had happened on my remotes more than once).
Try to clean the remote control (the housing, rubber pad with knobs, circuit board) with ethyl alcohol, when you clean the housing, you should also clean the holes through which the buttons protrude, there might be some dirt that keeps the button stuck.
It may also be a stuck button on the TV front panel, so check these too.
Also, it could be something else, i just wrote the description of a problem and the solution which to me seemed most likely.
Hope you get it fixed.
regards
3rq8 (Triarcuate)
Jul 25, 2009 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Volume won't turn down
Try the setup program. When you get to the main setup screen, look for a reset all to standard setting. That may solve the problem. If it doesn't then the sound module may need to be replaced inside the TV.
Apr 11, 2009 | iLO 3200 32 in. LCD Television
Tv ws-65511 volume stuck
Did you ever get this problem fixed? Ours just started doing the same thing. It worked fine the night before, but today it's doing what yours is doing. The remote stopped working for the TV. The remote still works for the cable box, but volume and anything related to TV function not. The screen flashes when we try to adjust volume or anything else, but resets to previous volume. TV not responding to any commands either on the front panel or remote.
Any ideas? Thanks, Patti
Aug 10, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
