The collet stocks and I don't know what to do? Any advice will be good, thanks
Hi, W/D here.
The collets are a friction fit, and tend to bind after being left in one position for a time.
Try this: Tap the bit, if there is one in the chuck, towards the motor. This sometimes creates the slack needed to remove the bit. Put a little light oil on the collet before you replace the bit.
If no bit is in the collet, try a light oil, and tap directly on the collet with the chuck collar off. Also, tapping from different angles after adding the oil will help to dislodge the collet.
One other method is to set and hold the shaft lock after oiling, and try to rotate the collet slightly while exerting an outward (pulling) force with pliers or channel locks. Be careful with this method, as too much force can result in damage to the collet.
Best regards, --W/D--
