Question about Electrical Supplies
I need to know how to wire a 1994 Damon motor home class a for a onan 4000 generator
SOURCE: Onan 4000 RV Generator - where is the oil drain plug?
It should have a cover on the floor bottom that is held in place with two torx (star) screws. remove the cover and you can remove the plug with a 9/16 socket.
Posted on Dec 02, 2008
  • 42 Answers
SOURCE: wiring diagram for Generac engine on standby generator
here is a wiring diagram for that engine:
Posted on Mar 13, 2009
erickg
  • 116 Answers
SOURCE: Oil type for Onan 4000 generator
SAE 15W-40 is what i used to use
synthetic? not sure about that one there may be oil pres switch that could give you a problem.
Posted on Apr 17, 2009
  • 127 Answers
SOURCE: I have a onan genset generator model #3.0AJ
The wiring diagram for the generator is pretty simple. You have three wires coming out, White/Green/Black. The black is the Hot, White is neutral, and green is ground. If the generator is running and you do not have power at the black wire, the problem is in the generator. Check the circuit breaker on the generator for OK. Make sure that power is passing through it.
Posted on Jul 05, 2009
  • 77 Answers
SOURCE: onan 4000 start good runs only ten minutsand shuts down,starts up
First locate the oil pressure switch and see if you can bypass it,then see if it runs. If not check the fuel filter and fuel pump,make sure solonoid for fuel pump is kicking on.
Posted on Aug 10, 2009
What is the point gap for model:CCKA-S/25830?
Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ...
www.partsfortechs.com > Home > Generator Part
Generator Parts Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ... for this plug require the spark gap to be set at .025" (25 thousandths of an inch).
Onan Gen HGJAB What is the best spark plug and gap? - Heartland ...
https://www.heartlandowners.org/.../39632-Onan-Gen-HGJAB-What-is-t...
Jun 8, 2013 - 3 posts - ‎3 authors Also what is the the correct gap on the plugs? ... brands · Generators; Onan Gen HGJAB What is the best spark plug and gap? ... Gap: 0.025
Nov 04, 2015 | Watts Onan Portable Generator - 4000 ,...
Onan 4000 microquiet generator
Check the ignition circuit, and trigger coil for correct resistance on the trigger coil, and the ignition coil. The trigger coil is a small module on the engine shaft near the flywheel.
Jan 31, 2015 | Onan Microquiet 3600 & 4000 Generator
My 1988 georgie boy motor home onan generator 4000 watt has no spark out of coil to plugs?
check and see if it gas a kill switch some were on it follw a black wire out of coil see were it goes maybe to a kill switch look for it
Sep 04, 2014 | Electrical Supplies
Need to know what the volts should be on the starter side of solinoid on a onan 4.0bfa r.v. gen.
Typically near full battery voltage. During starting this may fall to around 10 volts due to the high current once the starter motor engages.
Oct 31, 2011 | Watts Onan Portable Generator - 4000 ,...
Onan generator service codes
Check the spark plug and the ignition coil for good sparking.
Get the spark plug out, or with another spark plug connected to high voltage cable, outside the motor, the outer part of the plug connected to motor ground and see if spark is present at cranking.
Jun 30, 2010 | Watts Onan Portable Generator - 4000 ,...
Have crafsman 5500generac generator need to seperate genhead from
Remove all wiring. Remove four stator bolts. Remove stator. remove rotor through bolt tap end of rotor us a shaft in the rotor tighten bolt in tapped hole to remove rotor.
Mar 25, 2009 | Watts Onan Portable Generator - 4000 ,...
Onan 20K Generator runs constantly in stand by mode
Your remote start wires going into your transfer switch are closed, which means you transfer switch is the problem.
Feb 11, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
26 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
