Question about LG Cell Phones
My lg phone geniune battery power off - LG Cell Phones
Why doesmy LG vs910 display "usegenuine battery" power off, and has a ? In battery. Bar?
your Lg phone has detected a non- Lg mfg battery installed inside it , the ? in display is to "say" hey I don't know power level as I cant interface with this battery
Jan 15, 2016 | LG Cell Phones
Phone will not open
time to replace the battery or phone itself
Aug 30, 2017 | LG Cell Phones
On power up, why does it indicate 'use genuine battery', then shuts off?
If your phone does not indicate it is charging, the 'use genuine battery' message may its way of telling you the battery is defective.
Nov 23, 2015 | LG VX8350 Cellular Phone
When using the lg Voyager I can hear the person on the other line but they cant hear me .
Try this:
Remove the battery.
Hold power button for 10 seconds while battery is out to fully discharge the power.
Replace battery and reboot phone.
If the microphone still does not work then it would appear that your microphone has broken. You will either need to take your phone to a qualified LG repair place or purchase a new phone.
Jul 20, 2011 | LG VOYAGER VX10000 Cellular Phone
I have( LG CE 0168 model),this lg mobile phone but there is some battery problum. so tell me what did i do of that problum. and how because , i live in bijnor and there is lg costumer care but care service...
I have LG CE 168 mobile, But the battery is robbed, So I need to buyy the new battery. I dont know the battery No. So please give me the battery No. ....Thanks
May 23, 2011 | LG KG800 Cellular Phone
I have forgotten my security code now i can not use my phone.
Try 0000 or 1234 or 9999 (it may be five or even six zeros, or 12345, or 999999, depends how many numbers the phone will let u type in.
Hope that helps!
Mar 28, 2011 | LG GW300 Cell Phone
My lg dare died today, its been charging, when I power on, it says use geniune batter power.and powers down
Hi,i think the charger is getting bad and will need to be replaced due to wrong contact inside the charger.
Take care.
Aug 16, 2010 | LG VX8575 Cell Phone
I have an LG EnV that will pair but not connect with my LG HBM 210 headset. It worked before but just stopped.
Try removing the battery of the phone while the phone is powered on. Replace the battery, power on the phone, and try to re-pair your phone.
Jun 29, 2009 | LG enV VX9900 Cellular Phone
N73 battery lasts for only 6 hours ?
if it in warranty then just return back to NOKIA CARE back and tell the same ,,
otherwise it can be hardware fault,,, before all this plz try with same battery in other phone and check for ther same..
Apr 24, 2008 | Nokia N73 Cellular Phone
Wont turn on
Make sure the battery is seed properly. Also, sometimes removing the battery and cleaning the connections helps. Try this---remove battery take a qtip put a tiny bit of rubbing alcohol on the end of it (DO NOT SOAK IT!!!!!) clean the connections. Let dry for a few minutes, reinstall the battery.
I had a phone that kept turning off on it's own and that worked.
Again, DO NOT SOAK THE QTIP, JUST A LITTE MOIST, DO NOT USE WATER!!!!!!!
I CAN'T BE RESPONSIBLE IF YOU DO IT WRONG.
RUBBING ALCOHOL DRIES FAST
Mar 27, 2008 | LG VX9800 Cellular Phone
Cell Phones Logo
24 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
