Question about Sewing Machines
When sewing the thread gets caught up underneath with a L shaped piece of metal. It changes the tension and gets caught and I have to cut the thread
  • Sewing Machines Master
  • 11,462 Answers
Install a brand new needle.
Try slightly tightening the top tension.
If it still misbehaves, the machine may be out of time. Search for sewing machine timing or take it for service.
Posted on Apr 26, 2017
Bobbin thread keeps getting caught up when i begin to sew about 4 stitches in.
bird nesting is the result of incorrect needle thread tension
adjust the tension tighter
Oct 25, 2017 | Sewing Machines
Thread getting caught below and locks up machine.
Tale the metal case out that holds the bottom reel, there should be a tension adjustment screw, use a small screwdriver or thin knife, turn it anticlockwise, should loosen the thread, this should sort it. Clean out all the bits of thread of course.
Dec 24, 2014 | Sewing Machines
Singer 5050c top thread coming out of tension control during sewing
What if you get a thread stand? does it happen when stitching vigorously or normal stitching? Thread stands helps keep tension and avoid thread jumps etc...
Nov 15, 2013 | Singer 5050 Mechanical Sewing Machine
Bunching and knotting from underneath
check there is no dirt in tension discs and that there is tension on needle thread. check that there are no marks on the hook (sharp point that travels around bobbin)
Jan 27, 2013 | Sewing Machines
Bobbin trouble with my sapphire husqvarna
Check to ensure your needle is fully inserted and not bent or burred.
Then check to see that there is no bits of thread caught in the bobbin and race area.
Jul 15, 2012 | Husqvarna Designer I
Why does my 9000 keep jaming. I had it fixes and the problem still excist. I find that it balls underneath yet there seemsto be nothing uner in the bobbin case anywhere. I am tires of distroying towels...
What did they fix on the machine? Did they change the bobbin case? Many times the bobbin cases get burrs on them from broken or broken needles. Also the position bracket, (the elbow shaped piece of metal) that keeps the bobbin case from spinning around, has to be positioned correctly. Thread up the machine, put a small piece of cloth under the pressure foot, and turn the handwheel by hand, in the forward direction, and watch the upper thread as it comes around the bobbin case for every stitch, and see that it flows smoothly. If it hangs up any point, the problem might be the bobbin case or the position bracket. Also check the threading. Many times customers assume that the machine is threaded correctly and it's not. Be sure and rethread anyway. And make sure that there is no thread caught between the tension disks.
Apr 30, 2011 | Janome Memory Craft 9000 Computerized...
Viking Designer 1 balleds / Birdnest / issues after repaired from Husk service center in midwest - replaced thread needle and adjusted tension .. freequilting and embroidery situations
birdsnest refers to a mess of thread on the underside of fabric when you start sewing (after a few stitches all looks good). if this is the case and it is happening during embroidery, switch off jump stitch thread cutting.
if it happens at the start of normal sewing, either hold your needle thread when you start sewing or make sure the needle thread is under the presser foot and held by the presser foot when you start sewing. this way you will have an inch or so of thread on top of your fabric which you can trim instead of a mess underneath.
if there is a mess underneath for more than first few stitches, either your check spring in the needle tension area is set incorrectly, or your needle tension is set too loose (adjustable in sevice menu by tech only) or there is foreign matter caught in tension assembly preventing proper tension.
Jul 26, 2009 | Husqvarna Sewing Machines
Thread caught and messed up the tension spring.
You tension should always be between 3-5. There are several things that can cause a machine to not adjust properly. The most common is threading incorrectly. Another is pieces of thread caught in the tension assembly,usually between the metal tension discs. Try rethreading your machine with the presser foot in the up position.
Feb 27, 2009 | Brother Sewing Machines
Tension loose
When you raise the presser bar it should lift a small U-shaped piece of metal inside the head of the machine directly pushing a release pin located in the center of the tension post. You have to determine whether this operation is happening before you go any further. Sometimes the screw on the lifter bar loosens and loses contact with that U-shaped piece of metal. If that is working properly, then on your tension unit itself, starting with the parts going from front to back, you have a thumb screw, a number wheel, a lock, a beehive-shaped spring, and the next piece is the tension release cup. This cup slides on the tension bar with the piece of metal sliding into the bar which is split. That slight peice of metal that slides inside could be deformed. If that is the case, tap it gently to bend it towards the machine. This is the best that I can tell you right now.
Dec 15, 2008 | White Sewing 1418 Mechanical Sewing...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
