Question about Sport & Outdoor - Others
Will a plecostomus fish live in an outdoor pool?
Koi fish are dying in my pool
The pools have controlled (hi)ph and clor,also no oxygen or fresh water...Is not apropriate for fish.A ionised purificator will allow them to live.ceck this and read the comments:
http://www.youtube.com/watch?v=i8oF97_ZGPM
Aug 13, 2013 | Ed Hardy Koi Fish Seat Covers Floor Mats...
I have a fish pond and our new puppy has pushed some of the rocks surrounding the pond into the pond and has torn the liner. What is the best way to repair this.
drain fish pond see what kind material the liner is made of and trouble shoot get a bulge pump pump the water into something that can hold it maybe like a kiddies swimming pool or something like a bigger yard swimming pool for fish and water wlmart sells swimming pools
Feb 20, 2013 | Fish
Drainage plug will not seal as threads broken on pump. can be repaired? when removing plug to drain pump for winter part of the threaded area on the pump broke off.
YOU CAN GO TO WALMART AND GET THE SMALLEST LIVE WELL PLUG IN THE FISHING DEPARTMENT. OR DRILL A SMALL HOLE IN THE PLUG AND USE A STAINLESS STEEL SCREW AND SOME SILICONE , INSTAL THE SCREW AND WASHER FROM THE INSIDE OF THE PUMP IF POSSIBLE, LET CURE FOR A HOUR OR SO.. JAY
Jun 02, 2011 | Century New Magnetek Pool Spa Pump Motor...
Im cooking fish, how much oil ?
Enough to submerge the fish in the basket. Easiest way to get it pretty close:
1. Place the basket in the cooking pot.
2. Fill to the estimated displacement with water. The estimated volume would about half the height of the basket in the pot, if you were to fill the basket with fish half way. This way you know that you'll have enough to cover the fish when you start frying.
3. Measure the water. If you have the markings stamped in the side of the pot, this is pretty easy. Otherwise, pour the water into a gallon jug, keeping tally on how much water you removed from the pot. A partial gallon at the end is easily estimated. Works the same for liters, depending on where you live.
4. Dry the pot thoroughly before you add the oil.
Best regards, --W/D--
Jan 28, 2011 | Eastman Outdoors 38065 Turkey Fryer
How can you break your friends rocket fishing rod so that they cant have it anymore
Ha ha ha, Vaseline on the handle and then tell them to cast.....
Put it in the microwave and tell him that it will shrink to pocket size, but it will just melt into a pool of blue goo.
Good luck, please vote for me :)
Jun 25, 2010 | Rocket Fishing Rod
What cheap fish can i put in my pond? have gold fish and i want others
It depends on your climate. I would not recomend the same fish for Minnesota that I would for Nevada.
Dec 15, 2008 | Garden
Outdoor pool temperature
We usually heat ours to around 85?F. In fact, in the summer, we consider our pool cool if it stays below 90?F (where we live a 115?F is normal).
Aug 27, 2008 | RAYPAK JACKET TOP
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
