Question about Home
Ascentii-muw wont flush, the alarm goes off constantly and the water is backed up in the bowl
SOURCE: cadet 3 round bowl toilet not flushing all from bowl
You are probably correct, the water level needs to be raised. There are many different toilet tank systems, but all have some way to control the water level in the tank. Let me know if you need help figuring it out...
P.S. You'll have to take the lid off the tank, first...pardon me if that is too obvious
Posted on May 08, 2009
  • 62 Answers
SOURCE: basement toilet won't flush. water fills the bowl
Check your flapper line to the flush handle. The flapper is in the tank on bottom. There shoiuld be a plastic line to handle or chain. :)
Posted on Sep 07, 2009
  • 3006 Answers
SOURCE: water overflow from cistern to bowl
The shut off valve depends upon where your plumber fitted it and whether one was installed at all. If there's not one near the cistern then you'll need to find the stop valve which is on either the main household cold water tank outlet or if the cistern is filled directly by mains water then you'll need to turn off the main supply valve or even the valve in the street.
The fault is caused by a failed syphon assembly inside the cistern. Although it's possible to remove the faulty part and replace it the sheer number of different syphon assembly designs and the age of many of them usually mean that it's quicker and simpler to replace the entire assembly. Without knowing exactly which make and model of syphon you have it's impossible to give you any more specific details as the operating methods vary so widely, but if you're mechanically minded then you may well find that you can dismantle the old syphon and locate the failed seal. Sometimes all you need to repair them is an old car tyre inner tube and a pair of scissors. A repair often costs pennies and takes hours, a complete replacement syphon assembly often costs between £13 and £60 depending on the model and design (plus labour) but usually takes no more than around fifteen to twenty minutes to replace if the cistern is close-coupled to the toilet and a bit longer if it's an old-fashioned high level cistern with restricted access.
Given the need for guesswork based on the limited details in your question I hope that you appreciate my reply and ask only that you return the favour by rating my answer.
Posted on Oct 01, 2009
Testimonial: "thanks for the fast reply and solution"
  • 2702 Answers
SOURCE: Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
Posted on Oct 24, 2009
  • 10 Answers
SOURCE: When i flush the toilet, the bowl doesn't fill
there is an ajustment on top of float assembly
to adjust level of water in tank
Posted on Nov 01, 2009
My toilet flushes, then the water in the bowl drains over 4-5 minutes resulting in sewer gas smells.
Look inside the tank under the lid, it sounds like the flapper that lets the water into the bowl is getting hung up on something when you flush. It could be the flushing lever. This would cause the flapper to stay open letting water to just pour into the open sewer line. It should be a simple fix. Just see what is binding the flapper & make an adjustment.
Dec 02, 2015 | Duravit Starck 2 One-Piece Toilet
Why doesnt town water cut off and just keep filling the tanks till they overflow we have tryed everything
Troubleshoot Your Toilet Without a Plumber
Overflowing, constantly running and sweating toilets can test a home owner's sanity. ... take for granted--until we can't take a shower or make the toilet flush properly. ... If none of the above does the trick, you may have a misadjusted or faulty fill ... the waterlevel a half inch below the top of the overflow tube inside the tank." ...
Emergencies - Overflowing toilets - Toiletology 101
You can't just lower the water level in the tank; you need to displace some of ... and the ballcock and flapper are working properly and shut off when the tank is full. ... The bowl is filled with the water that goes into the overflow pipe. ... Unfortunately, when a toilet bowl is clogged and the water level rises and doesn't flush the ...
Nov 19, 2015 | Town Home
Toilet fills with water then slowly goes down
you have a blockage maybe outside in your shores
Oct 16, 2012 | Home
After installing a new flush valve, the water level in the toilet bowl seems to be much lower than it was with the old flush valve. Is there any adjustment for the water level in the toilet bowl?
Yes,there it is!You can adjust your water level at the flush valve..You can see the ball there you need to adjust that so that the water level of your tank goes to your desired level.
Jul 29, 2011 | Kohler 3386-6 Rialto Skylight Round Front...
Replaced the seals because it was running. Water is still leaking from the tank somewhere so it keeps's constantly leaking and refilling. how can I repair this.
You say you have replaced seals. I assume that you are refering to the flaper valve that controls dumping water from tank to bowl to flush. To make sure you have a good seal put a dozen or so drops of food coloring directly into tank when it's full and observe for a hour or so to see if water in bowl is discoloring. If it is then you are still leaking there. You can shut off water supply off or flush toilet and manually hold flush valve closed. Check to see if there are any rough spots on flapper seal that could stop flapper from sealing good. If you find rough spot then make sure the surface is dry and sand lightly with medium grit sandpaper.120 grit or finer.
One other thing to check is if your toilet has the plastic or rubber tube that goes from the flush valve into the overflow. Make sure that this tube does not set below water level in tank when it is full as this can create a suction or syphon,
Hope this helps you. Thanks
Jan 10, 2011 | American Standard Home
Water leaking inside toilrt bowl
The flush megnisems rubber has parished.
Step1. open sistern and locate the flush meganisem, [shoold 90% of time be the gajet in middel]
Step2.unhook or unscrew all the handels conected to it,
Step3. turn the meganisem left, it wil pop out and at the bottom after you pop it out u see a black rubber that looks damaged, go to plumbing shop with the rubber and they will give u 1 ,its cheeep.
that should fix it.
plz rate my advice
Jul 12, 2010 | Eljer Toilet Onepiece Canterbury ...
Flush button won't work. 12 yr old Duravit Toilet
The push button siphon assembly is worn out. Just replace it entirely.
May 26, 2010 | Home
Low water level in bowl after flushing
The small black tube that goes into the overflow is used to fill the bowl after flushing. Would check to make sure that water is coming out of that tube at full force or if its coming out at all.
May 11, 2010 | Eljer & Elongated Toilet Bowl
No water in bowl
check the water stopper in the bottom of the tank is it closing all the way.
Apr 25, 2010 | Eljer & Elongated Toilet Bowl
Home Logo
35 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
