Question about Watches
Bracelet change size - Watches
Tip
How to manage your SUBMARINER's size to fit your wrist
Take of your ROLEX, look on the inside of the bracelet. Near the area where you have the crown, there is a miniature circle, push with your thumb on it with strenght, you will hear a click . You pull your bracelet , it will open, then you look on the sides of the bracelet, and you insert a needle into the little screws on both sides, and then you choose the size you wish for your watch , and then put the circle back and close everything again.
on Oct 10, 2010 | Rolex Oyster Perpetual Submariner Date...
What size of battery fits guess steel
Just take it to a local jeweller and they will change the battery whilst you wait for $6 to $8. There are so many batteries and usually you can't by just a single one in the small sizes that watches use.
You often need a special tool to get the back off, and a jeweller's eyeglass to see the tiny screw and the right screwdriver to fit it.
May 20, 2016 | Guess Waterpro Bracelet Watch
Where is the spring loaded pin
In the bracelet where the bracelet enters the sides of the watch. Also in the catch if it has size adjustment.
Dec 23, 2015 | Watches
Spare bracelet links required for Ellesse watch model 03-0041-201
Hi
Does anyone know where i can get links for Ellesse watches. I have a range of different watches all too small.
Grateful for any help.
Jun 15, 2012 | Watches
Adjust bracelet on sea spider?
Thank you for contacting FIxYa.<br /> I suggest you take your watch to a reputable local jeweler for sizing. Expect to pay a nominal fee (around $5) for this service. Do not attempt to size your own watch! You may damage or scratch the watch and bracelet. The liability is yours.<br /> If you still decide to do, follow instructions given here:<br /> <a href="http://www.webwatches.co.uk/how_to.htm" target="_blank">http://www.webwatches.co.uk/how_to.htm</a><br /> Best wishes. Jewel
Aug 26, 2010 | Invicta Watches
How do i get extra links for a concord veneto
Go to watchbands.com, enter your model number and bracelet size and problem solved!
Feb 10, 2010 | Movado Concord Saratoga Chronograph Watch...
Need pin for band on Fossil Am 3754
Measure distance between the lugs of your watch. Find the nearest watchmaker and ask for spring lug of that size (this is if you need to attach band to watch).
If you need a pin for bracelet links- measure width of bracelet and ask for split pin of that size.
Dec 18, 2008 | Fossil Watches
I want to adjust the steel bracelet on my new GMT II
You can do it yourself but proper watchmakers screwdriver is needed.
Check the sides of your bracelet and you will see screw ends with grooves. Unscrew them and adjust your bracelet (take the links out). Then screw them back in.
Regards
Arthur
Dec 13, 2008 | Rolex Watches
Watches Logo
16 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
