Question about Technics Televison & Video
I have technics eh50 nd switch on its turn of standybye what to check
    Top Expert:
  • Technics Master
  • 75,025 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Apr 24, 2017
Panasonic DMR EH50. Picture is dominated by the colour pink. TV not affected.
Please check your Blue and Red component cables on both the recorder and your TV. One is probably loose.
Apr 07, 2014 | Panasonic DMR-EH50 DVD Recorder
I have a Technics SL-BD20D turntable and want to connect it to a Technics SA-EH50 amp. Can this be done. Please tell how
Hi, you need a preamp to boost the line level if no dedicated phono input is on amp. Cheers John. Styluscity
Dec 28, 2011 | Technics Audio Players & Recorders
I have sc-eh50 technics, yes I know its old, LOL I have my laptop working through this, sounds good. I now wanna use a Microphone for my wifes birthday party, at the same time playing music IE when...
Old? Try 70's and 80's vintage hardware ;-)
Your PC probably supports a mic (most do). Investigate the Sound Controls to enable and control it and look for the (usually Pink) input on the front panel.
Be cautious about feedback. It can kill tweeters in an instant. Experiment with speaker loudness and microphone proximity to them. Keep a good audible distance.
Mar 12, 2011 | Technics Audio Players & Recorders
Amana front load washer door wont unlock
Nd is drain error.
Check inside the control assembly, you may have a technical diagram with instructions pocked in there.
You will need to check the drain pump hose for blockage.
If that is not enough to fix the problem, then the fault may be the pressure switch, the pump, or the control assembly.
In that case the best thing to do is calling the support number listed in the owners manual to contact Amana.
Dec 13, 2009 | Amana Washing Machines
Actually I have a 4 yr old dmr eh50 panasonic dvd recorder
Make sure remote is set to unit code ex: press enter and 1 at same time see if this matches try enter and 2 or enter and 3 see if this matches and works
Oct 03, 2009 | Panasonic DMR-E50 DVD Recorder
Looking for the region codes!
I want to make my panasonic dmr-eh50 to multi dvd region player. How to get the dvd multi region code?
Jun 24, 2009 | Panasonic DMR-EH50 DVD Recorder
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
Check your user guide for the answer.
Nov 08, 2008 | Panasonic DMR-EH50 DVD Recorder
DVD Recorder Screen keeps saying HOLD and not switching on
The Child Lock Deactivates All Buttons On The Unit & Remote Control.
To Deactivate Press & Hold (OK) & (RETURN) Simultaneously Until "X HOLD" Disappears.
Oct 28, 2008 | Panasonic DMR-EH50 DVD Recorder
Does the DMR EH50 work with satelite tv
Yes Connect using Scart
Sat to EH50, Sat to TV as per page 15 of the manual and it should work fine mine does
Dec 05, 2007 | Panasonic DMR-EH50 DVD Recorder
Televison & Video Logo
Top Technics Televison & Video Experts
ray gallant
Rick Hickerson
Rick Hickerson
Are you a Technics Televison and Video Expert? Answer questions, earn points and help others
